SOURCE: 42EDT41 Plasma
Found a professional service tech who fixed my problem over the phone. Hire with confidence at a fraction of the cost you been quoted. He guaranteed his work and will ensure problem is resolved. Contact Dave at 503-432-9904. He has several postings on this site. My TV is still working fine.
Regards,
Paul
SOURCE: red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
SOURCE: My Hitachi P50x01au plasma TV
I would open back and check all boards for cracks, this is a problem with these sets.Then count the blinks on the set and see if it stops for a moment and starts back.
SOURCE: Hitachi 42EDT41A has a black bar from top to
It is a X sub board pdoblem,and you can check and see if they have the board at www.partstore.com
SOURCE: My set is a Hitachi
I am sorry to tell you that this is a problem with the panel itself. The only possibilities for this problem are the buffer boards and the Plasma Panel. Since you have replaced the buffers already it only leaves the PDP. The panel is very expensive and costs nearly as much as a new tv, if not more.I hate to say this but the best way forward would be to sell the working parts of the set(which should fetch you about 300$ on ebay) +couple hundred more you will get a new tv(LED backlit LCD recommended).
