Question about Dell PowerEdge Computers & Internet
Running Dell r815, 48 core, 256g Ram, 2 - dual channel 8g hba, 8g path all the way to SAN (pooled solid state, 450g, 1T disk). Installed and fully patched Windows Enterprise 2008r2 server and SQL Server 2008r Enterprise. After reboot, everything is running great. Then as the week goes on, there is a degredation of performance. There are heavy ETL loads at night. Heavy reporting during the day. We have all appropriate maintenance jobs (indexes, stats, ect) running daily with logs and full backups. Everything across the board takes longer each night and each day. By the end of the 7 day ETL week, the Saturday processes run 2 to 4 times longer. Reports run 2 to not returning. All we have to do is cycle the SQL Server services. Processing goes back to normal. We manage over 1500 instances on 1400 servers. We have other large dell r900s and r810's. This is our only 48 core dedicate SQL Server instance. Joseph Devereaux First Niagara Bank, N.A.
SOURCE:
SOURCE: Memory and RAID Card for a Dell 1600SC
May be worth reseting the bios using the on-board jumper.
Posted on Jun 01, 2007
  • 19 Answers
SOURCE: slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Posted on Aug 15, 2007
  • 9 Answers
SOURCE: Automatic database backup
These instructions are for Microsoft SQL Server Standard.
Go into the Enterprise manager.
Select your server on the tree view on the left. Go all the way down to "Management" and click on "Backup".
This will allow you to set up the backup.
Check the box called "Schedule". This will allow you to select a schedule for automatically performing the backup.
Good Luck.
Posted on Nov 10, 2007
  • 73 Answers
SOURCE: Flashing orange light & diagnostic cd will not load
You should install the system administrator tool within windows. use the following link and install the software. it will tell you exactly what is wrong.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R108443&SystemID=PWE_PNT_P3C_2450&servicetag=&os=WNT5&osl=en&deviceid=2331&devlib=0&typecnt=0&vercnt=19&catid=-1&impid=-1&formatcnt=2&libid=36&fileid=143370
Posted on Feb 07, 2009
AmerIHCan
  • 14 Answers
SOURCE: Dell PowerEdge 2900...USB Keyboard and USB mouse
Is it possible this is where the problem started? When updating the controller...
http://support.microsoft.com/kb/906690
I was going to suggest opening event viewer either through Administrative Tools or bye typing eventvwr in the Run dialogue box. You will see one column on the left and one on the right. The one on the right shows errors and performed operations alike, when you click on an area in the left column.
You'll see an "Event" tab if you scroll to the right after clicking on "System" in the left. Any red Xs mean error. Double click or right click & select "Properties" to read the error. Highlight and type Ctrl+C to copy the text in the Description area and search Google for an answer, careful where you click, reading the address for the location of the site, looking primarily for the support.microsoft.com website for solutions.
Go to the keyboard & mouse manufacturer's website and download any new drivers. You might also find legitimate drivers on the Dell site for the Host controller, USB controller & mouse/keyboard. Make sure they're for your system/model/components. Reboot if asked and allow divers to install.
My vote...
You can then/also try uninstalling the Keyboard & mouse drivers and rebooting to safe mode, then uninstall the Controllers themselves. Reinstall on reboot to normal Windows and try using only certified drivers... or drivers that came with the mouse/keyboard or that you downloaded as instructed earlier.
Uninstalling and then reinstalling iIMHO is the best method rather than updating. Sometimes drivers overwrite and become corrupt.
Try to only stick with microsoft & Dell (your manufacturer) for driver updates. Programs that connect to sites and download new drivers for your system often install incorrect updates. Even if your system has a say, Toshiba AB-01234-YX, the driver for the component might not be written the exact same way Dell/the computer manufacturer has written it. You also do not know the programmer and cannot honestly say you can trust them when installing and asked "are you sure" if it is not digitally signed.
HTH.
Posted on Apr 23, 2010
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
Mar 05, 2018 | Dell Computers & Internet
Have powespec G214. Has i7 but only one core is running. would like all
Ubuntu will NOT run on a muti-core motherboards properly. You should've just installed Windows 7 Ultimate 64-bit with SP1 or Puppy Linux Live.
Feb 01, 2014 | Powerspec G214 Desktop Computer; Intel...
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
Manufacturer specification states that this desktop(motherboard chipset Intel 865 GV) is capable with dual chanel memory..but in CRUCIAL.COM it shows max memory for this desktop is 2 GB, i was just...
Dual channel memory means DDR2 RAM, it is one of the latest technology in RAM. You can use two RAM but performance will be very similar to 2GB only since
Apr 23, 2010 | Dell Dimension 3000® Pentium® 4...
My friend left his OPERATING SYSTEM disk at my house and when my computer got sick I Formatted MY Hard drive with his disk!!Being that he also had a Gateway (not the exact same model and 3 years older)with...
I think the problem lies with your dual core processor. Under Windows XP, these processors need to have the correct drivers installed to fully take advantage of the fact that they have 2 cores.
Try downloading and installing these drivers from the AMD website:
Dual core optimizer Processor driver
As always, back-up your important data, and preferrably create a restore point before going through with driver updates.
The radical choice is, obviously, to reformat using your own disk, as this should install correct drivers for all your hardware.
Dec 10, 2009 | Gateway GT5220 PC Desktop
Problem while upgrading my RAM
some systems require matching pairs, so since you are using mismatched, it may only recognize 1 GB of the 2gb module
Sep 27, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Installing Ram in a Dell Laptop
Yo u have 2 slots in u r machine I am sending u details information of updradation in ur machine :
frequency of ram should be
667 MHz Dual Channel DDR2 SD RAM
option 1.
A system ready for the next generation of applications and games 3 or 4GB1 Dual Channel2 DDR2 SDRAM
2.
A system capable of handling Windows Vista® Aero as well as today’s latest games. 2GB Dual Channel2 DDR2 SDRAM
3.
Basic performance for the Windows Vista® AeroTM interface (PCs purchased with Windows Vista Home Premium and less than 1GB of memory will NOT be capable of running Aero). 1GB Dual Channel2 DDR2 SDRAM
4.
Basic performance, lowest initial cost (Windows Vista® Home Basic) 512MB Dual Channel2 DDR2 SDRAM
Jun 21, 2008 | Dell Inspiron 8600 Notebook
Driver for Fibre Channel HBA A5158A
Can you share the firmware version of HBA & server 7400 BIOS version
Dec 18, 2007 | HP A6795A#0D1 Network Adapter
Slow file transfer
Aug 15, 2007 | EMC CLARiiON AX150 (AXS207500KIT) Network...
System not detecting the disk array.
Hi there, You apparently don't have downloaded all drivers and software needed. I'd go to: http://www.sun.com/products-n-solutions/ hardware/docs/Network_Storage_Solutions/Adapters/index.html. Install the software in the following sequence: 1. Download and install Sun StorEdge SAN Foundation software 4.2 packages and patches. See Sun StorEdge SAN Foundation Software 4.2 Installation Guide, 817-1244. 2. Download and install the appropriate JNI 2 Gb PCI Single and Dual Port HBAs packages and patches. See JNI 2 Gb PCI Single and Dual Port Fibre Channel Host Bus Adapters Release Notes, 817-2260. Good luck!
Sep 13, 2006 | JNI FCX2-6562-E Network Adapter
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
83 people viewed this question
Ekse
Clive
Clive
