As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
If you need further help, reach me via phone at
https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
