Hi Ashley,
It
clearly indicates that the battery of your laptop has deteriorated and
cannot hold enough charge to run the system without AC Adaptor/ external Power Supply Source. So, the
battery is supposed to be replaced with a new one. You may have noticed that the battery would be empty when you start the netbook and it shows 100% (fully charged) in a very less time. This happens due to the faulty/ deteriorated battery, which has very less charge holding capacity and hence shows fully charged in no time. If so, I suggest that you
buy a new genuine battery (not any replacement), as genuine battery
would last longer and serve you best.
On the contrary, if the battery gets charged normally and takes about 50-60 minutes to show 100%, then you may get the netbook checked by any authorized professional for complete hardware (Battery/ AC Adaptor etc).
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
