In word - I'm editing a document in "print layout" view and for some reason my tool bars have disappeared - the only way to get them back is by moving my mouse over them - its very frustrating
Right click on the "print layout" and uncheck the option "Minimize the Ribbon" .
In the upper left corner, there is the multi-colored "Office Orb." Beside it is the "Save" icon and then the "undo" arrow. To the right of those icons is a down arrow with a bar over top of it. If you hover, it should say "Customize Quick Access Toolbar". Click it and the bottom menu item should be "Minimize the Ribbon". Uncheck that to get your menus back to normal.
If this solved your problem, please rate me -- trying to get my "Wiz" rating so I can offer Premium help.
Thanks,
Chris
Have you perhaps resized the Word application to a larger size than your screen? Try maximizing the word window and see if it still happens. Just a very odd problem -- almost seems like your menu bar has become "pinned" somehow. I didn't realize that Microsoft provided a way to pin it -- possibly some shortcut keyboard command you hit.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
Create a New Document
There are several ways to create new documents, open existing documents, and save documents in Word:
You will notice that when you click on the Microsoft Office Button and Click New, you have many choices about the types of documents you can create. If you wish to start from a blank document, click Blank. If you wish to start from a template you can browse through your choices on the left, see the choices on center screen, and preview the selection on the right screen.
Opening an Existing Document
Saving a Document
Renaming Documents
To rename a Word document while using the program:
Working on Multiple Documents
Several documents can be opened simultaneously if you are typing or editing multiple documents at once. All open documents will be listed in the View Tab of the Ribbon when you click on Switch Windows. The current document has a checkmark beside the file name. Select another open document to view it.
Document Views
There are many ways to view a document in Word.
To view a document in different forms, click the document views shortcuts at the bottom of the screen or:
Close a Document
To close a document:
Hi Chris - I will try it - but I don't think it will work because that "hides" or "unhides" the ribbon whereas mine is just disappearing from view while I'm working on the document and reappears when I move my mouse up to the top .... if you see what I mean!?!
