The imei code is unique for each phone. There are 3 ways to find the imei code for your iphone:
1 - About screen - Tap Settings > General > About to view your serial number, IMEI/MEID, and ICCID.
2 - Remove the SIM tray, the serial number and IMEI will be printed on the SIM tray
3 - If you still have the device's original packaging, you can find your serial number and IMEI/MEID printed on the barcode label that's affixed to the packaging.
You probably just typed it in wrong. O's look like 0's(zeros), B's look like 8's... Did you put in the dashes, or leave them out... Try it both ways. Good Luck!
Sim 3 serial code is key that helps you register to an account and each code has one account ,here are some sim 3 serial codes that you can try using it .
It works if you sign up with http://thesims3.ea.com and then you can send them an email, that the reason why you wan't the registration code : "My CD Case didn't show anything, it's no registration code in there, so thats why i need some of again please!"
And it really works! you have to wait, but.. its better than you not being able to play the sims 3 ?? Just try it! It'll be worked, FOR SURE 1000000%!!!
You can get the PUK code from the Service Provider.
A phone asks puk code when you try wrong PIN Code more then 3 times.
Then if you try to put Invalid PUK code more then 10 times your sim card is gone for good.
You will need to get a new sim card.
Google. =] Just type in Sims Serial number (or serial code, cd key, SN).
For example:
Sims Vacation serial number
Sims vacation cd key
Sims vacation SN
Just have a look around and you should be able to find a few without a problem. If that doesn't work, I suggest putting "list" within the sentence. That sometimes helps you get different serial codes rather than generators for codes.
For example:
Sims Vacation serial number list
Sims Vacation cd key list
Hope I was of some help. By the way, which Sims are you trying to get the serial code for? Sims Vacation cd key, will obviously not work if it's Sims 2, and vise versa. So just make sure you search for the specific Sims game you are trying to install.
