To reinitialize the IS-SPX-1000 unit to its factory default settings:
1.
Unplug the unit from the power.
2.
Push the reset button and keep it pressed.
3.
Power up the IS-SPX-1000 unit.
4.
Wait with the reset button pressed for at least 8 seconds.
5.
Release the reset button.
6.
The IS-SPX-1000 unit will now boot in the factory default mode.v
Factory Reset Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
Remove the Magellan Maestro from the holding cradle.
Hold down the "Power" button on the right side of the device, until the unit powers on.
Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
On the RoadMate, press + + - - + -
The "hidden menu" will appear.
From there, you can access the
shell and perform a hard reset.
To reset a PiranhaMAX 210 depth finder to factory settings, follow these steps:
Turn off the unit by pressing and holding the power button.
While holding down the "Zoom-in" and "Zoom-out" buttons on the keypad, press the power button to turn the unit back on.
Release all three buttons when the unit beeps and the "PiranhaMAX" logo appears on the screen.
The unit will now ask if you want to restore factory defaults. Press the "Menu" button to confirm.
The unit will ask if you want to restore all settings to the factory defaults. Press the "Menu" button again to confirm.
The unit will then reset all settings to the factory defaults and reboot.
Note: Resetting to factory settings will erase all user settings, including saved waypoints and custom settings, so be sure to back up any important data before resetting.
This is the "master" reset procedure. No other way of clearing the unlock pattern. *******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. . Step 9- Press the Menu" button to select "Yes- delete all user data". Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Yes, there is a way to reset it. You can try the reset button under the faceplate, or a Master Reset. Keep in mind, a Master Reset WILL ERASE ALL OF YOUR FAVORITES. In order to do a Master Reset the unit must be off. Press and hold the bottom right of the screen, then press the on button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts. To use the reset button, you must remove the faceplate carefully (put your fingernail or another object in the indentation on the top of the faceplate, and pull it toward you). Then press the reset button on the right hand side of the unit.
