Panasonic DVD-LS82 Logo
Anonymous Posted on Jul 27, 2011
Where can you fine DVD LS82 dvd mechanizing part to buy, this part is the part that play the dvds
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Jul 27, 2011
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563148
Points
12312
If you are looking for the optical pickup ( the most common failure part), the part number is: RAF3400A-G and is available from Encompass for $65.80 plus shipping.
Dan
1helpful
2answers
Nd 3550a will play and record cds and records movies with sonic 5.3 but will not read or play dvds in any mode. drive does not show disc in machine. Running xp dell 4600
For playing DVD's you need to install DVD softwares which is came along with the drive Or download and install the same from vendor website will resolve your problem.
Revert back for more assistance.
Formating dvd to work in all dvds
if u have region specific DVDs then it may not play on some DVD Players that can be used only in some regions....so buy DVDs that can play in ur specific DVD player
My laptop dvd just stopped playing my data cds and dvds that it used to play just fine. I get the message ''unsupported format in Drive E''. The dvd plays audio cds and dvds just fine. I can burn new cds...
dear sir good day please test the cd on an other lab top so you will know the problem and i think it will come from the data cable of your cd thank you
1helpful
2answers
Netflix dvd not playable on SamsungDVD/VHS
Buy a cheap DVD player under $50 they play anthing.I have a $600 Toshiba Tivo DVR that won't play some DVD s.My $32 RCA plays anything.Good Luck.
My samsung dvd player will not play dvds, but it
Are you trying to playing recordable DVDs (DVD+R or DVD-R) ? if so, try playing original DVDs (the type you rent or buy) those are pressed DVDs - if it works, then your player does not support DVD-R or DVD+R - If you are using a computer burner that supports bitsetting you can change the booktype of a DVD+R to DVD-ROM to fool your player.
If however your player cannot play either DVD-R, DVD+R nor original DVDs and only plays CDs, then your dvd laser diode is finished - there is one for CD and one for DVD, this is rare but happens, there is nothing you can do, any repairs would be very expensive - you are better off getting a new DVD player they are very inexpensive now and any repairs will cost you multiple times a new DVD player.
4helpful
3answers
Wrong disk
I looked at everybody's ideas, and none of the ideas seemed to fit my situation. My DVD player has been working fine for one month. I got a new DVD today in the mail. It froze, and then began to display the WRONG DISK message. Then, nothing would play on the player, All of the DVDs that had worked fine before, now would not play. They all said WRONG DISK. I tried reaching under and trying to clean the laser lens, but that did not fix the problem. I am not saying that this will fix your problem, but this is what fixed mine.
1. Place the DVD player on a table
2. Plug in the DVD player.
3.Push the OPEN button so that the DVD platter extends outside of the player (It now looks like it does when it is ready for you to put a DVD in it to play it.)
4. Unplug the DVD player. (Now the power is off, and the platter is still extended.
5. Remove the cover of the DVD player being careful not to damage the extended platter.
NOTE: With the platter extended, looking slightly from the rear, under where the DVD is spun, you will be able to see the Laser lens. It will be covered by the mechanism that spins the DVD. The lens will be connected to a mechanism that that has two rails on either side.
6. Grasp the plastic surrounding of the laser lens area and pull the entire mechanism toward the rear of the DVD player.
CAREFUL: DO NOT YANK THE MECHANISM BACKWARDS as this will break off the laser unit. This mechanism is being moved with the resistance of many gears. PULL SLOWLY AND FIRMLY, and the entire mechanism will move on the rails until the laser unit is clearly visible to you and completely from under the spinning mechanism.
7. Since the lens was clearly visible now, and easily accessable, I carefully and lightly cleaned the lens with a Qtip and alcohol.
8. Replace the cover on the DVD player
9. Place a DVD on the platter.
10. Plug in the DVD player
You will find that you no longer get the WRONG DISK message and your DVDs will now play properly. As I said, just reaching under and cleaning the laser lens did not seem to fix the problem. It was only when I moved the entire laser unit from under the spinning mechanism, and forced the DVD player to realign itself when it powered on, did the DVDs begin to play again.
My Poloroid DVD will play the Commercial DVDs like Fiox & Hound and Stuart Little, but suddenly will not play the 30 minute PBS Kids Songs DVDs and the Little Einstein Dvds-they played fine before, but I...
I read the other people's problems with the same type DVD player and discovered that the player is only covered by a 30 day warranty...and it would cost more to fix than it is worth. I will just never buy another Poloroid......a lesson learned! I will use our laptop to play the 30 minute DVD's that the player won't play and when the player dies, it dies!
1helpful
Playback of dvds
is the country code different on the dvds than on the unit?
2answers
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
