Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Posted on Aug 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Half screen lighter than other half
Hi, after watching the tv for 20 or so minutes half the screen goes lighter than the other half. So there is a line down the middle where half is darker than the other. Any ideas on the problem?
  • skillz42 Aug 31, 2008
    I thought it might have something to do with the power supply, do 42 and above plasmas have two different power supplies for different parts of the screen?
  • Anonymous Nov 27, 2008
    Ya the TV PDP 4294 seems to overheat so I put a fan on it and it fixed it. It came back two week later and is staying with the line down the middle even with the fan.
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Aug 31, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
33839
Points
113
Faulty display panel or faulty display driver
  • Anonymous Aug 31, 2008
    There is one power supply but it is divided into several circuits. You have line volts coming in AC then there are regulators to keep the various supply voltages steady for each circuit area. each manufacturer takes time to disign power supplys for their sets but no matter who makes them the theory is the same for all. I hope to help you but it very hard to try and explain something especially when I cannot be at the device haveing trouble. One word of caution for you be careful handleing your plasma GLASS is heavy have a friend help you move it some sets you can remove the back while it is still sitting on its base (stand) some have to be placed face town on a study bench or table use a blanket to protect the face of the set. Just be careful and try not to get so discouraged even as long as I have been in electronics repair I still get a little tight. Most repairs for your plasma will involve replacing entire circuit boards. Some manufacturers parts are realativly (cheap) in price some will make you cry.
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
1helpful
2answers
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
My tv's screen is messed up its like half light and half dark
This is a drive issue caused most likely by the driver board for the LCD panel. Best contact the manufacturer regarding a warranty repair if they will do it. It will be best if you bought an extended warranty.
1helpful
Hi, when i turn the tv on after its been off for a while, half my picture is clear and the other 1/2 is darker (like its warming up). the problem goes away after 10-20 minutes of watching it. I had the tv...
ytou have a bad connection on the cable going from the T-con board to the lacd panel Carfully reseat both connectors they a delicate be carefull the t-con board is located at the top center of the unit
Funny half screen problem
Maybe you got dried capacitors near the vertical IC or the IC himself are damaged you need to be atech for make the rapair because is dangerousli make it
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Screen Problem
I have been trying to fix one of these tvs and found out from a repair man that the lower half going blank means a problem with the lower buffer. and that is also what the manual I downloaded says.
have you checked that?
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
