The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Paste this link into your browser for the specs
http://www.google.com/url?sa=t&sourc...Ja2NwA&cad=rja
I have a John Deer 115 riding mower with a toe out problem on the front wheels. Is there an adjustment or parts that I can purchase to resolve this problem?
Regarding the pivot bushings that you are talking about: do you mean the bushings right on the steering column (there are 2 on the bottom, and then 1 real small one way at the top)?
