SOURCE: Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
SOURCE: lexmark x4530 multifunction printer/copier/scanner. The
There could be something blocking the scan communication - possibly a firewall. If you have a firewall enabled on your computer, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
SOURCE: photo copier won't copy
I would suggest you to try making a copy and check if you can see thelight of the bulb, if not its a hardware issue, you need to get it replaced
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
