HP LaserJet 4 plus Printer Logo
Posted on Jul 27, 2011
Where can i get a laserjet 4 (c2001a) installation cd? It works with one computer (the printer) but not any others. I tryed to copy the driver from one computer to another and that screwed up the one that worked. some of the computers are xp64 and others are xp32. I have been to HP and they have the 32bit driver but not the 64bit. There is no exe on the download. Lost and need help....thanks for any help...Donni
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jul 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
3702
Points
50
The laserjet 4 is a standard driver already included in windows xp. You shouldn't actually need to download anything. When installing the printer you should be able to choose HP from the list and then navigate to HP Laserjet 4 in the list. When you do this it may need the windows disk if you don't have the i386 directory copied to your PC. If that's the case then just pop in the windows CD and point it to "CD-Rom"\i386 and it should find the drivers on its on.
2answers
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
tip
How to detect and test a printer or any other device
Ubuntu live CD (that we can get free or make copy) detects a lot of drivers. For example hp laserjet p2015 so you can print you document on ubuntu form your hard drive if your printer can't work with vista. The amizing thing is that you don't have to install ubuntu, just boot from the CD/DVD and when you finish shut down the computer and remove the CD witout any effects on your current operating system
on Jul 31, 2010 • Computers & Internet
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
1helpful
2answers
I lost my printer cd and have got a new computer now
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=306507&lang=en&cc=us&prodTypeId=18972&prodSeriesId=306505&taskId=135
Copy and past this link into your web browser. Then, since you didn't mention which OS you are using, find the OS you currently have. Click and download the driver. Once you have downloaded the driver, open it and it should self extract and install. Follow the on screen instructions for the install and wamo!!!! Happy printing........
89helpful
5answers
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
20helpful
6answers
HP Laser Jet 1320 Printer installation SPAM BELOW AT 1*800*532*4187
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
9helpful
5answers
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
2answers
Help me
i read wat u all complained above n i'm moved, but if u use win xp with service pack 2 and u are connected to the internet, then u don't need the driver CD again. as long as xp is able to detect the new hardware connected, it will only take time for it install and copy all the files. i bought the same printer 1st week of june n i did not use the driver at all.xp did it all for me... for more help u can contact me.
2helpful
6answers
Hp 1320 driver BEWARE SPAMMERS 1*800*532*4187
Go to HP.COM to the drivers and support tab, search for your driver and download
k24674
Grand Canyon Tech
Grand Canyon Tech
