Pretty simple operation...here's an overview of the component locations:
Remove the 3 screws at the bottom of the front panel. Lift panel out at the bottom and it should fall down. Discharge pump is on the right-hand side. Simply disconnect the hoses from: 1) the tub and from 2) the outbound discharge hose. Then remove all screws holding the pump in place. The electrical is a quick-connect adapter.
Save yourself a mess by draining the assembly first -- just follow the instructions for draining/cleaning the filter in the Use & Care manual
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
