Good day!!!
You need to replaced the spray head...
you can buy it to this site:
this is a spray head kit..
http://www.cw-usa.com/accessories-home-bunn-springsprayheadkit.html
this is spray head only:
http://www.coffeeespressopro.com/bunn-sprayhead-6-hole-sst-6-078.html
I suggest to buy the kit because its compete..
Thanks for using fixya..
These happent because the dripping water is coming faster through spay head than it should be. the water remains more time in filter thus the coffee rising up and pass over filter and filter holder thus some coffee grounds end in the pot.
The fisrt thing you should do is to descale the machine. If you have not made this periodicaly then perform it two times.
The second thing you should check the filter holder if it fit perfectly with base so to block the ground pass thought
We keep our machine in pretty good shape by running a water and vinegar solution throught it. I take it that is what you mean by descaling. I would think that descaling would just cause the water to run faster.
Could the spray head be allowing too much water flow? Can the spray head be replaced? Where could I obtain spare parts and drawings for this type of coffeemaker?
Yes
