Maytag SAV5710 Top Load Washer Logo
reliableservice Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAYTAG WASHER SAV5710AWW please give step by step instructions on how to remove thje pump and replace it , a service manual will be a help thanks
  • 1 more comment
  • reliableservice Jul 27, 2011
    you gave me info on a direct drive the model i gave you SAV5710AWW is a belt drive please advice
    was a big help thank you
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Jul 27, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14456391
Points
60858
Easy job... turn the washer away from the wall and take off the small plate at the back, this is the plate pump is there in corner held in there with 3 3/8 bolts. Remove hoses and remove pump, previouslly you will get some water drain washer first by gravity.
Remove the clips holding the pump to the motor shaft. Put your bucket under the pump and take the clamps off the hoses. Pull the pump toward you to remove it from the motor shaft.
Additionally, this video could helpful like a reference guide...
Good luck.
  • ZJ Limited
    ZJ Limited Jul 27, 2011
    Visit this link Service Manual (page 27) to check this procedure.
  • ZJ Limited
    Your welcome; thank you for usign Fixya.
I have a Maytag Neptune TL Washer that won't drain. I think the drain pump is clogged. How do I remove/disassemble the cabinet so I can get to the drain pump?
See this link for the Service Manual and a pic of Drain Pump/Drain Line on the right side of the machine. leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you
You can place the machine in Service Mode once you have the Service Manual and turn on the drain pump thru console commands.
As I mention in the other post here on FIXYA you can only access the drain pump with the front cover removed.
If you place the machine in a Spin Only cycle will it complete the cycle?
If you can give a bit more detail on your troubleshooting maybe I can help.
My Maytag washer m.mtw58701tw0 doesn`t drain or spin and I just replaced the motor with a new one. What could be the problem?
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. Please rate my answer as 4 thumbs up. thanks. Joe
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Replace the pump on my washer
If they're star shaped, they're called Torx head screws
2helpful
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Instructions to replace bad pump on Maytag top loader, model SAV5710AWW
hi thanks for the question pull the washer away from the wall you will see a small plate at the back remove this plate pump is there in corner held in there with 3 3/8 bolts remove hoses and remove pump you will get some water drain washer first by gravity please accept and positive feed back is nice thanks the appliance doc
Maytag Mav5000aww having pump problems ... I wish to purchase a shop manual or at least have someone give me step by step instruction to remove the cabinet..
www.applianceaid.com/norgewash.html gave us the info on popping the lid to access the screws for removing the front panel. Piece of cake from there...
Thanks for asking. Other promises of help followed up with password requirements and requests for dues to join their super-seeker club.
Cannot drop the pump to replace the belt on our maytag washer model #sav5710aww
Use a gentle hammer action on all 3 sides where screws go in should come out
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
