Hi, The error code means a problem with the heat sensor. Failure Condition Check/Repair F24 WATER TEMPERATURE SENSOR ERROR 1. Unplug washer or disconnect power. Thanks, E-ware
Code
If the water temperature sensor (NTC) value is out of range (23°F to 217°F[-5°C to 103°C]) during the water-heating step
of the WASH cycle.
NOTE: To find correct Ohm reading refer to the Water Temperature Sensor section.
2. Check the water temperature sensor and connection to it.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Refer to the Water Temperature Sensor section.
