My netbook compaq is no sound comes out. only headset working pls help me tnx! COMPAQ MINI CQ10-525DX I USEd TO PLUG IN TO MY COMPONENT AND OTHER SPEAKER FOR PC. I TRied THE STEP SUGGESTed to UNINSTALL DEVICE AND REINSTALL HD AUDIO DEVICE, BUT I CANT FIX THE PROBLEM PLS TRY TO HELP ME TNX SO MUCH!
MINI CQ10-100 LAPTOP.
NO OS stated XP, VISTA? what?
what fails we cant guess what does and not.
1: ear buds 3.5mm (they must work using CP +SOUND)
CP + sound + sounds tab + test. asterisk.
bingo sounds now????????????????????????
2: head phones with 3.5mm phone jacks, these work like day1 new and now. do they/? as do buds .
3; USB devices, do not use them until you learn how. ask. USB is complex and fights the stock system.
3b, if you do use USB devices only the makers driver works, not MS drivers.
4: using external 3.5mm jacked speakers do work if they are for PC and marked amplied and has there own volume controls yes, turn that up too.
next time tell what is being plugged in exactly
we cant guess any of that.
ever.
if your earbuds work why would you change the sound driver, the green jack works , you proved that.
the word you said headset means ZERO
nada , nothing;.
tell what headset means. and win.
the key missing critical fact here missing.
the test is with earbuds, 3.5mm from dollar store.
the acid test for that 3.5mm jack is that.
Is the volume turned up?
SOURCE: ii have compaq presario c785tu
i have compaq presario c700 pc sound and audio not working. control panel shows no audio device. pls help.
SOURCE: kindly provide me compaq presario C700 audio driver...tnx.
Audio Driver: First download and install the UAA driver from the
following link before installing the audio driver:
UAA Driver
After installing this, download and install the audio driver from the
following link:
Download Audio Driver for Compaq Presario C 700
in case you need any other driver or help do comment here
I hope this resolves your problem
all the best
SOURCE: i have no sound no
i need the serial number off the computer -- i can get you the audio card part # once i hear from you
SOURCE: my compaq hp mini cq10
do you have a blinking cursor on the screen? if so, hardware issue - hard drive
