Copy all data to another HDD and do a full format.
A full format means that when windows asks how to format your Hard Disk drive Select the normal NTFS format.
Do not select the Quick format option and format the entire HDD during windows installation.
Do not format the drive in FAT32.
Testimonial: "thanks sir..i did same n working"
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Testimonial: "thanks sir....prob solved"
Can you still access the laptop internal hard disk? If so, merely back up everything important to another computer and run CHKDSK to test your internal hard disk. Of course, performing a full formatting process there also can help resolve some simple hard disk problems.
But, if you cannot access the internal hard disk right now for some reasons, like RAW file system error or more, you can firstly go take your left drive data out with computer hard disk file recovery software and go format it there.
Hope these words could help you somehow.
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
