Optoma PK201 PICO Pocket Projector Projector Lamp Logo
Posted on Jul 27, 2011
I have optoma pk301 pico projector. suddenly few white spots have appeared on screen which do not go away
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2198
Points
Hello, I have the same problem with a pico 201, and can not solve it, I can not contact optoma support team
Sam Jollow
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 02, 2012
Sam Jollow
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8430
Points
23
On my projector it shows connecting pc only
Please check the cable ,this problem looks with your RGB cable
Optoma PK301 lost a color
it is not correlated with bulb
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Picture is snowy on most the picture. Cannot see picture because of the white snow.
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
have a nice day!
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
2helpful
I have optoma pk301 pico proyector,suddenly a few white and dark spot have appeared
Its a bad DMD chip. Seems this is a common problem with the PK-301's sadly. Mine is out of warranty and a new chip runs about $180.
3answers
Optima Pk301 pink cast
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa
9helpful
2answers
I have a Optoma HD 67 projector and suddenly it has a lot of white spots on the screen, even if you remove the input cable the white spots stay there
as greg instruction, it is very detail,
usually, white dots problem is reason of the DMD. perhaps the manufcaturer can't directly and singly sell a parts for end user, they always let you send broken machine to their repair store, then ask for high repair cost.
actually, optoma HD67 projector with 1280*720 pixels, so i think you should buy a 1272-6038B DMD chips, if you need further help, please freely contact me again,
I copied a presentation to my Optoma PK301 Pico Projector and at the end of my slide show it started to appear some type of a blur at the screen, this blur has a shape of my first page of presentation and...
Did you let the projector sit with that slide on for a while? If so, what you have is called burn-in and it is when the image gets kinda locked into the LCD, and it will show up as the LCD get warmer. If you still have a warranty, I would return it for a new one, and make sure that the images used on it don't remain fixed for a long period of time. Hope this helps!
32helpful
7answers
My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
