How do I clean the machine? It seems to not be cleaning clothes very well lately and clothes and stuff are coming out with a lot of hair on them (girls flat) our washing machine is a esprit 500 5.5kg heavy duty. Thank you
My hotpoint is same you have to pull machine out then tip on side carefully then remove black sump pipe right by pump at Back machine clipped on so remove clip holing to drum and pump. Also the pressure sensor might be attached just unclip then clean filter out and put back clipping back on tight. Hotpoint have self cleaning pump on these models but has catch by pump that can get blocked only new models of hotpoint made this easier hope this helped :)
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws
underneath. The
panel will drop and come off. Drain off the excess water from the hose
you
see.The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect
water.
Unscrew the filter cover and twist the filter out. Clean out all the
stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits
of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works
great on
all front loaders. Use hot water with the Affresh pellet with no clothes
and
run the machine through a cycle.Also
helps with any stagnant water smells. Have you cleaned out your pump
lately.Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
underneath. The
you
water.
stuff and
great on
all front loaders. Use quite hot water with the Affresh pellet with no clothes
and
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
underneath. The
you
water.
stuff and
great on
and
rchu is exactly right. No need for a complicated disassembly. If you have never pulled off those end bearings/caps, the hair may be very impacted, but removing it should solve the problem. The instructions will tell you by color (yellow for mine) which pieces come off for cleaning. Be sure to remove all such pieces. If the fit seems tight, it's probably because a lot of stuff got stuck in there. Be gentle but firm, and things the should come off will come off. Once you've cleaned all the pieces, the thumping should be gone.
This is sometimes caused by grease coming from the drum bearing through a failing seal. If this isn't checked and repaired as necessary, the drum bearing will fail pretty soon and then the machine will make a nasty grinding noise and that will be the end of it. I hope you have some other cause in your case! Do make sure the filter is cleaned and then run the machine on a hot cycle with no clothes in it to give it a really good clean.
