Remington MS2-390 Electric Shaver Logo
Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mom got me this razor since i turned 13 and needed to shave. Every time i turn it on it wont shave. there's this button on the front of it that releases a blade and i dont know what its for.
shaveroutlet.com
Level 3:
  • Remington Master 1,652 Answers
  • Posted on Jul 27, 2011
shaveroutlet.com
Remington Master
Level 3:
Answers
1652
Questions
0
Helped
765000
Points
4209
The button on the front releases the long hair trimmer. It is for cutting hair that is too long for the regular shaver foils to shaver
You will find the user manual for model MS2-390 available at shaveroutlet.com. Click on the link below and scroll down to the 'user manual' link near the item price
http://shaveroutlet.com/shavers/remington-ms2390-microscreen-500-shaver-p-564.html
3answers
What is an electric shaver?
An electric shaver is a grooming device designed for shaving facial or body hair using mechanical blades driven by an electric motor. It typically consists of a set of oscillating or rotating blades enclosed behind a perforated metal foil or comb. The motor-powered blades move rapidly, capturing and cutting the hair that enters the perforations. Electric shavers are known for their convenience and efficiency, as they eliminate the need for water or shaving cream. They come in both foil and rotary designs, catering to different preferences, and are suitable for various hair types. Electric shavers are popular for providing a quick and comfortable shave, making them a common choice for individuals seeking a time-saving and modern grooming solution.1_3_2024_5_47_45_pm.jpg
tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 • Health & Beauty
What are the advantages of straight razors over modern razors?
The one big advantage of the straight razor is that if you take care of it properly it can last for a long time unlike modern razors which you simply throw away after a few shaves when they come too dull to use.
I bought my husband a new senso touch razor i would like to know how they rate with other shavers also are they hard to clean
Hi cuke693,
I work for Philips Consumer Lifestyle and received a Senso Touch 1180X/40 for free as part of a Home Test. I have never been a fan of electric razors because of incredibly sensitive skin and fast growing facial hair. I do however, use the Senso Touch 1180X/40 in between shaves with a manual razor, and I am very happy with it. It doesn't irritate my skin, the shave is very close, and use/care is easy and ideal. I also like the fact I can use it safely and comfortably in the shower, too.
Depending on the model you have, you can find great resources at www.philips.com/support. Just enter the specific model number to access the product specific page which includes FAQ's, manuals, videos, chat, etc. (http://ow.ly/6j6O2)
As for cleaning, these are the instructions for the 1180X/40 (again, for model specific information, visit the above website):
Regular cleaning is important to maintain an optimal shaving result.
1. Turn the shaver on.
2. Rinse the shaving unit under a hot tap.
3. Pull the top part of the shaving unit from the bottom part.
4. Rinse the bottom and top part under a hot tap for 30 seconds.
5. Reassemble the shaving unit and carefully shake off excess water. Let the shaving unit dry completely.
3helpful
3answers
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
14helpful
2answers
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
2helpful
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gene Lawson
Mike Cairns
Mike Cairns
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
