Mitsubishi VS-55609 55" Rear Projection Television Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
States input lock, and asks for password we do not have a password and only a universal remote
Anonymous
Level 3:
President:
  • Master 1,284 Answers
  • Posted on Jul 26, 2011
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498723
Points
3271
On a Mitsubishi remote control when it asks for the password you would simutainiously press the "9" and "QV" buttons until it unocks, then you would change the password. I am not sure this will work on a universal remote. I hope this helps anyway : )
Remote codes for samsung blu-ray
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We recently bought a universal remote control for an extra bedroom and ... To control a Samsung Blu-Ray DVD player with an RCA universal ...
3 Digit Universal Remote Codes For DVD ' Codes For ...
codesforuniversalremotes.com/3-digit-universal-remote-control-codes-d...
... of the 3 digit device codes for DVD and Blu-Ray 3 Digit Universal Remote Control Code List ... Need 3 digit remote code for samsung blu ray player BD-J5100.
Support - Blu-ray Players BD-H6500 ' Samsung Home Audio
www.samsung.com > ... > Blu-ray Players
Samsung Electronics
How do I unlock a WD-52525 Mitsubishi I have a Rca universal remote I dont know the password
You must use the factory remote. Mutlibrand will not work for this option. No matter the universal remote, you need the original. No other way to do this.
1. Press MENU on original remote only
2. Then press 2,4,7, and 0
3. Select "initialize" and then 'ENTer"
This will full restore to factory original settings. but you need the original Mitsubishi remote.
2answers
Proscan tv input without remote
Without its remote control, you can't select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
How do I change the input so I can use the rca jacks in from the tv with the remote I have a salvania .
You are asking about the input selection of the tV, by using a RCA universal remote I assumes and posts this solution. All setup codes fro a tV with remote control might not work with all functions as it meant to be. Try an other setup code fro your TV with your remote. There is no other way than this. Universal remote codes for Sylvania TV are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
What is FPA lock on mean
FPA locks the front buttons so children can not access programs without the remote. Use the remote to access the main menu then parental controls. On some models you might have to select special or chanell menu first. If FPA is on it will ask for a password. Turn off parental controls and all should work. This will require the original remote or a universal.
1helpful
There was a parental lock code on our ps2 when we got it, is there a override code I can use to unlock it? I bought it at a yard sale last summer and they never mentioned that they put a lock on the DVD......
Try these directions, they *should* work.
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if you?"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
2helpful
How do I bypass Mitsubishi VS-4502R security code?
Don't know that you can do it with universal remote. to release channel lock on previously locked channels or inputs, 1 press the menu button 2 press 5 3 press 2 (4) the display then askes for I.D> number (5) press 9 and quick view at the same time, this turns channel lock feature off.
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
1helpful
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
