The drain hose connecter, which accepts a garden hose type coupling is an intricate part of the unit. It is not removable. If yours broke OFF, that's a different story. However, that Part # 5214A20027A Drain Hose Connect is no longer available. As are many other parts for Maytag Dehumidifiers, that were manufactured by the now defunct, Fedders.
Unfortunately, I do think you'll be able to run out to the local hardware store and get parts to fabricate one. As the lion's share of the part is internal. http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282294&modelsID=116727&typeName=dehumidifier
I'm sorry I don't better news for you. Thanks for choosing FixYa.
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status:
In Stock
Price:
$107.79 -
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
