SOURCE: no signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
SOURCE: Hi ,Marantz SR7200 , i am getting an audible hiss
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7200-Receivers-manual/id/511dj782/t/2/
Simply run a composite video (RCA) cable to the TV.
