I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Can i use acrylic paints to paint the OUTSIDE of my microwave and toaster oven? Thanks!
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
SOURCE: paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
The inside coating on the upper ceiling of the microwave has split and peeled away so there is a large hole. where the aluminium is showing through from underneath this is partially rusty.
Is the microwave safe to use in this condition?
Is the microwave repairable?
thank you
I have peeling paint inside my microwave. It is down to the medal . It is a GE spacesaver XL1800 - about 3 or 4 yrs old. I am affraid to use it. Any suggestions
paint peeling off ceiling all over the place. i cover anything i'm cooking with a paper towel or paper plate, but is it safe? Model is GE turntable JES1036PWH03
THE PAINT IS PEELING OFF ON THE TOP OF MY G.E. MICRO.
UNIT IS ABOUT 4 YEARS OLD. G.E. SUGGESTS USING WB64X5022
PAINT. COST ABOUT $35.00. THEY SOUNDED KIND OF SURPRIZED THIS HAPPENED LIKE THEY HAD NEVER HEARD OF IT. SEEMS TO ME A LOT OF PEOPLE ARE COMPLAINING ABOUT TJIS PROBLEM.
can i use acrylic paint on the outside of my microwave and toaster oven? Thanks!
