Kohler 100-Amp Automatic Transfer Switch - RDT-CFNA-0100A Logo
Posted on Nov 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the weekly scheduled start is supposed to occur the engine appears to be trying to start but stops then tries again....just will not start on automatic. I have checked the battery (70 amp with trickle charger) and it is fine. The engine starts on manual fine. I have checked all other fuses and circuit breakers all fine.
Chuck Graybill
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Nov 26, 2017
Chuck Graybill
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
40352
Points
206
The problem is not likely battery related. It sounds like either an ignition or fuel control relay that is not actuating due to missing electrical voltage.
2answers
I have kohler 20RESA generator. I cannot clear the fault that says "engine m/n invalid shutdown". Can anyone help with this? I did go through the reset procedure, but fault reappears immediately.
Emergency shutdown operation is required when one of the above conditions occurs in diesel generator set.Diesel generating set itself has an emergency stop button, at this time, press the emergency stop button or quickly press the stop control handle of fuel injection pump to the stop position, the diesel generator will quickly cut off the load, and immediately close the throttle, while the red "emergency stop" light is on. Need to press the button again to delete the emergency stop signal. If there are serious faults or distribution faults, you can also press the button on the control panel, and the unit will stop immediately.
In fact, all faults always give operators some warning signal before spare parts break down or engine damage occurs. So the operators need to be smart, and notice alarm signals (sudden drop in oil pressure, abnormal sound, etc.) and immediately stopping the engine.
Emergency shutdown operation is different from normal shutdown operation.
Emergency shutdown operation.Once the operator finds that there is a serious fault or distribution fault in thediesel generating set, he can press the emergency stop button of the control panel to stop the unit immediately. If there is no special circumstances, we advise users not to stop the unit at will through the emergency stop button.
1helpful
Problem with lamp turning on
maybe try turning off at wall rebooting device can harm the computer if you turn off both you may turn off modem box thingie
Icant record some programs it shows TO BE ANNOUNCED
When you connect to the Tivo service, you get 2 weeks of scheduling information from the day you connect. This program may be airing beyond this two weeks. If you know for a fact that the program is airing less than weeks from today, if may have been cancelled or something. Check the home page of the channel it was supposed to appear on to verify.
Acer desktop power button faillure and STOP: c00021a BSOD problem
Can you do a system restore/recovery? Try boot to "last known good configuration" ? Have you added any new hardware or software?
I AM THE PROUD OWNER OF A SSANGYONG REXTON, FITTED WITH A MERCEDES E320 ENGINE. LAST WEEK ON THE HIGHWAY, THE ENGINE STARTED TO RUN UNEVENLY WHEN I STOPPED AT THE OFRAMP AT THE ROBOT, WITH NO POWER. AFTER...
I had the same problem of loss of power with my Rexton E320, especially at low speed , I changed the plugs but the problem could not go away, until I changed the fuel filter and that problem is gone. I have made a lot of kms now without any such problem, try that, it might work.
My 2003 ford focus ZTS dohc 16v leaks water (not coolant)
There are only 2 ways water can appear that I know of.
(1) Naturally occurring from combustion while you warm up the engine. It lays in the exhaust until it evaporates with heat or makes its way out little bleed holes in the mufflers.
(2) Air conditioner condensation off the evaporator which is SUPPOSED to drop thru a drain hose to the street. The hose can get plugged and it could leak out higher up maybe.
Your air conditioner works even in cooler temps to dehumidify the windshield(in DEFROST or MIX modes). This resulting water is supposed to drain thru that hose off your heater plenum.
don-ohio
Windows explorer, desktop manager & task scheduler stops working again n again. How to fix it?
If this problem has been occuring only recently (last couple of days or weeks) then you can do restore to an earlier point. It's likely that an update or program has been installed and conflicts with desktop manager the others.
You can find this on your Star Menu under Accessories/System tools. Choose a date that you know for sure was before this problem started.
Hope this helps! Rate my solution!
1helpful
Engine and electronics die on ecceleration and remain dead for awhile
ALL Grounds Need to Be Checks on this Including BATTERY They MUST Be CLEAN this Sounds Like a Poor Ground Problem.
Radio CD not working & lights don't flash remote keylock
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
