Toys Logo
Posted on Jul 26, 2011
Is there Dorabase. On wii - Nintendo Toys
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Jul 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
4326
Points
64
They only contain dorabase and dorabase2 on nintendo ds. sorry im sure it would be a amazeing game for nintendos wii. i hope this helps
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
8helpful
2answers
I dont know how to download netflix on my wii
Connect your Wii console to the Internet A broadband Internet connection and access point are Follow the steps below to get connected.From the Wii main menu, use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet. Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks,The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.Once the Wii finishes downloading any updates, you will return to the main Wii menu screen. You will now need to download Netflix Instant Streaming for Wii from the Wii Shop Channel, then connect your Wii console to your Netflix account. Please see the step-by-step information below to finish the process and start watching Netflix content on your Wii.Download Netflix Instant Streaming for Wii from the Wii Shop Channel Now that your Wii console is connected to the Internet, you can download the Netflix Instant Streaming for Wii from the Wii Shop Channel. Once it's downloaded, you'll use it to stream movies and TV episodes with your Wii.
1 Select the Wii Shop Channel on the Wii Menu.
  1. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement.
  2. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
    • If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right.
    • If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
  3. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  4. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account. Continue reading for more information.Connect your Wii console to your Netflix account Before you can watch TV episodes and movies streaming from Netflix, you will need to connect your Wii console to your Netflix account.On your WiiIf you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  5. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to http://www.netflix.com/wii. (You will need to log into your Netflix account if you're not already logged in.)
  6. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  7. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  8. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu
2helpful
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
  1. On your Wii
  2. On your home computer
  3. Still on your home computer
  4. Back to your Wii
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
How did the prince find rapanzel
Nintendo Wii Errors- How to DIY Go online to find experts that may guideyou step by step.These men online may show you how to fix your console just asan experienced repairman would fix it, but you won't even pay $5 to most ofthem! All these problems can be completelyfixed by you without the use of any external agency. Nintendo Wii: Memory Management, Gamesand Disc
1. Nintendo Wii: Data management
2. Nintendo Wii: How to Copy data to SD card
3. Nintendo Wii: SD Cards
4. Nintendo Wii: Making sure your SD card is compatible
5. Nintendo Wii: Known compatible devices Image files 6. Nintendo Wii: Known compatible devicesMovie files 7. Nintendo Wii: Error Message Disc couldnot be read/Unable to read the disc 8. Nintendo Wii: Cleaning game disc 9. Nintendo Wii: Disc ejecting automatically(including "An error has occurred eject disc") 10. Nintendo Wii: Games freeze while ingame play 11. Nintendo Wii: Message "Disc NotRecognized" 12. Nintendo Wii: Message "An ErrorHas Occurred" 13. Nintendo Wii: Disc Problems requireNintendo Service 14. Nintendo Wii: Erasing Game CubeMemory Card Data NintendoWii: Common problems 1. Nintendo Wii: Fixing time settings forloss time 2. Nintendo Wii: Delay response(display/video and audio) 3. Nintendo Wii: Can't get past"Language Select" screen 4. Nintendo Wii: Hard/Soft reset How-to 5. Nintendo Wii: Character/Cursor move ontheir own 6. Nintendo Wii: Adjusting the ParentalControl Settings of the Wii console Nintendo Wii: Error message "MessageBoard Data is full" 2. Nintendo Wii: Warning message "Becareful about posting too many messages" 3. Nintendo Wii: How do I replyto a Memo? - Why Can't I reply to a Memo? 4. Nintendo Wii: Multiple messages beingreceived from Nintendo
5. Nintendo Wii: Unable to receive emails with images attachment NintendoWii: Repairing and Disassemble Guide 1. Nintendo Wii: common error code listand description. 2. Nintendo Wii: disassemble guide 3. Nintendo Wii: Internal fan replacementguide 4. Nintendo Wii: DVD Drive playerreplacement guide 5. Nintendo Wii: Repairing DVD drive NintendoWii: Balance Board Problems 1. Nintendo Wii: How to fix problemssynchronizing the Wii fit balance board 2. Nintendo Wii: Wii Fit - TakingConsistent body test measurements Nintendo Wii: Wiimote/Remote common problems 1. Nintendo Wii: How to Sync a controller 2. Nintendo Wii: All Wii remotes will notsync with console 3. Nintendo Wii: Cursor is off center,jerky, erratic, or disappears etc. 4. Nintendo Wii: Remote buttons aresticky or stuck down. 5. Nintendo Wii: Buttons not responding 6. Nintendo Wii: No static, or cracklingnoise or no sound from Wii remote speaker 7. Nintendo Wii: No shaking,vibration or rumbling in remote 8. Nintendo Wii: Batteries drain too fast.How to increase life of your wiimote battery 9. Nintendo Wii: No cursor during game 10. Nintendo Wii: Tilt problems 11. Nintendo Wii: Message "There isno Mii save data on your Wii Remote. Format this save data?" 12. Nintendo Wii: How to repair a wiimote NintendoWii: Sensor bar Problems 1. Nintendo Wii: Disassemble guide -Sensor bar tear down 2. Nintendo Wii: Repairing a broken cableon sensor bar 3. Nintendo Wii: Adjusting thesensitivity on the sensor bar 4. Nintendo Wii: One dot during Sensitivityadjustment Nintendo Wii Power Problem 1. Nintendo Wii: No power 2. Nintendo Wii: The system plays forawhile but then shuts off on its own 3. Nintendo Wii: Power light does notturn on 4. Nintendo Wii: WiiConnect24 Settings Detailed description and fixes to all theerror codes Nintendo wiirepair guide Good luck and happygaming...
Our problem cantains a Wii.Our problem is how to get Netflix on the Wii without a disc or anything. We tried to fix it by putting in more information.
  2. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement. For help locating the User Agreement, click here.
  3. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
  4. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  5. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
Printer-friendly version
  1. On your Wii
  4. Back to your Wii
More support for Netflix on Wii:
1helpful
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
2answers
I can't get wii points
There are two ways to purchase Wii Points:
Purchase Wii Points through the Wii Shop Channel:
Using a Visa, or MasterCard, you can purchase Wii Points through your Wii console using the Wii Shop Channel's secure servers. To purchase Wii Points through the Wii Shop Channel:
  1. Access the Wii Shop Channel through the Wii console's Channel menu.
  2. If this is your first time using the Wii Shop Channel, read the User Agreement and click "I agree" if you understand and agree to the terms. Click "Okay" after reading the Wii Shop description.
  3. Once on the "Welcome to Wii Shop Channel" screen, select "Start Shopping."
  4. Click the "Add Wii Points" button.
  5. Select "Buy Wii Points with a Credit Card."
  6. Select the amount of Wii Points you would like to purchase. (Please note there is a maximum number of points that can be available on each Wii console.)
  7. Select the credit card type you would like to use to buy Wii Points. The Wii Shop accepts Visa, or MasterCard.
  8. Enter the credit card number, expiration date, and three digit security code. Select "OK" when finished.
  9. Enter your city, state, zip, and county. Click "okay" to continue. Please do not input any punctuation, such as periods, commas, and apostrophes into the street, city, or county fields. For instance, "St. Clair Ave" would be "St Clair Ave" when entered.
  10. Review the purchase details on the confirmation screen, and select "Yes" when finished.
  11. Once the purchase is processed, a confirmation screen will appear indicating that Wii Points were added to your Wii Shop account.
Redeeming a Wii Download Ticket
    Follow these steps to enter a Wii Download Ticket and receive the item.
  1. With your Wii console connected online, select the "Wii Shop Channel" from the Wii Menu. wiispeak1.gif
  2. From the Wii Shop Channel main menu, select "Settings and Features." wiispeak2.gif
  4. Locate the 16-digit Wii Download Ticket number. Point inside the rectangle and enter the Wii Download Ticket number. wiispeak4.gif
  5. Select "Now" to start the download. Once the download is complete, the item you are downloading will appear on the Wii Menu.
2answers
US Wii Console with Wii Fit (PAL)
As far as I know unless you buy region unlock wii software then you will have to return them.
Here is a site which will give you more info : http://www.squidoo.com/region-unlock-wii
1helpful
3answers
Wii
check wii console is connected then insert wii fit cd and see what happens put new batterys in remotes and make sure wii works before installing wii fit
Top Nintendo Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Nintendo Toy Expert? Answer questions, earn points and help others
