D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
Anonymous Posted on Aug 30, 2008
Can I piggyback a wireless router onto a hard-wired router?
I currently have a hardwired D-Link EBR-2310 and I'm using all 4 ports, including one into which my laptop is plugged.. Is it possible to plug a DI-624 into this to get additional ports and enable wireless for the laptops we have in the household?
We have 2 desktops that I want to keep hardwired; but we'd like to use the laptops wireless.
If yes, how do I do it?
If no, how do I replace the EBR-2310 with the DI-624? I no longer have the DI-624 installation CD.
Thanks!
  • Anonymous Sep 01, 2008
    Thanks for the info. I don't have the setup CD anymore; but I did a chat session with Randy V and think I'll end up doing just what you suggested!
Anonymous
Level 3:
  • D-Link Master 6,487 Answers
  • Posted on Aug 30, 2008
Anonymous
D-Link Master
Level 3:
Answers
6487
Questions
6
Helped
1556512
Points
18452
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
D-Link 4-Port Ethernet Broadband Router EBR-2310 (EBR2310) reset password
On the back of the router there is a reset button. You may need to use a paperclip to get to it. With the power on, push in the reset button for about 30 seconds. Release the button, and let the router cycle thru lights. The router should now be reset.
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Replaced a Linksys befsr11 with D-Link Ebr2310 and
Have you changed the settings on the other computers....
you didnt say if it was wireless or wired?
Check the configuration of the router as well
Heres a link to the support site for that router http://www.dlink.com/products/?tab=3&pid=EBR-2310&rev=EBR-2310
goto this link
http://192.168.0.1
and put in the user "admin" and no password to access the setting of the router
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
2answers
Broadband
purchase and install a broadband router. connect both computers to the router. make sure to follow the particular routers setup instructions fully
What is the default password for Verizon modem using a D-link EBR 2310 router...?? O_o
The default user administrator account is: Admin
The default password is: <blank>
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
