Hi.fan is secured by a screw.Yoou just need to remove those screws to get access to the fan.
What is your question? You gotta do what you gotta do to get it fixed. Be careful. unplug it ;) If you have a question i will be more than happy to address it. Thank you.
Best reguards, Premium FixYa Support
First check the fan bearings/bushings for wear. Then look at the fan blades carefully that there are none that may be loose if riveted to the boss and that the boss is secure on the shaft. Lastly make sure that all the blades pitches are exactly the same and that the blade run in the same arc - none bent out of line. Any diffefence in pitch or alignment will cause the fan to run out of balance.
Sorry no, I have no specific information on your unit, I was working on general solutions related to the symptoms you described, but from what you have further said, it sounds like it might be a centrifugal blower, in which case most of what I have related will not apply, bar the bearing/bush part. If it is a centrifugal blower with a series of half tubes making up the impeller, the chances are that dirt accumulation in some of the vanes might be causing an imbalance. The whole blower would come off as a unit and will probably not come apart, but if removed, you will be able to see the impeller and clean out the scoop like vanes.
Hello...to repeat, I was ONLY ABLE to remove the ai rconditioner's plastic casing. I am NOT able to see the fan, it is encased/housed at the top of the unit and appears difficult to access. How do I remove the fan casing? Do you have service manual for this specific unit? This is the 13,000 BTU model, not the 10,000 BTU. (Don't know if there is much of a difference, just want to be clear). Please understand I am NOT AN EXPERT so please be simple in your explanations and define technical terms. Thank you.
I have a Sharp portable a/c model CV-P13PX. The fan has begun to rattle and make a lot of noise. I have taken the a/c unit's plastic casing off, only to discover that where the fan is located (at the top of the unit) is, for me, inaccessible...at least without proper instruction. I would appreciate some advice. If someone could be simple and specific in how to get access to the fan, it would be the first step towards solving my problem. A service manual would be very helpful. PS: I've had this thing for barely 2 years and make sure it is clean...clean filter regularly, etc. I feel like the fan has never been quiet and has just gotten worse, especially since I've read more customer reviews online. The thing sounds unbalanced or is hitting against something. If no one can offer SPECIFIC advice for me, please say so.
How can I access/remove the fan housing to view fan?
What do I need to do the repair the rattling, noisy fan?
