My truck is 1998 vortec 5.0 lts 305 8 cilinders and it turns on and it runs but if I whan to accelerate more when runing it lows and if i push the accelerator more it turns off I have changed the fuel bunb, filter, distributor and rotor and it does the same, and I changed the presure regulator that is under the spider,
could it be that the pressure regulator is defective because it doesnt it doesnt emits smoke,
I will appreciate your support
my truck is 1998 vortec 5.0 lts 305 8 cilinders and it turns on and it runs but if I whan to accelerate more when runing it lows and if i push the accelerator more it turns off I have changed the fuel bunb, filter, distributor and rotor and it does the same, and I changed the presure regulator that is under the spider,
thanks for your response, and could you please tell me where is the ignition coil located?
regards.
thanks for the support it has a spark plug wire too right?
if the fuel pressure is good(60 psi), then check the ignition coil for corrosion
