SOURCE: Router won't connect to the internet.
bypass first the router and check if there is an internet connection. It might be no internet service at that moment.
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
SOURCE: Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: [email protected]).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Testimonial: "Ah!Brilliant! This was fantastic instructions on how to fix such a really simple problem I had no idea I was having! "
