Nikon Coolpix S3000 Digital Camera Logo
marchel47 Posted on Mar 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pics gone in DCIM folder. Using a Nikon s3000 coolpix camera, connected to computer, F:\s3000 is detected, within it is DCIM folder present, and within DCIM folder presents Nikon100 and Nikon101 folders, where boths folders have photos in with in. SO i try to select some photos in Nikon101, about 100+images by cut and paste into new folder newly created named 'new folder' in F:\s3000\DCIM. Progress was seen when the images is being trasnfer. BUt then suddenly upon viewing the DCIM folder, the 'new folder' has gone along with the images! it cannot be view within the memory card. I have tried go to folder option fo the computer to click on 'show hidden folder n file' but the folder still cannot be view. my computer os is Window 7, my memory card is Nikon SDHC 4GB. PLS HELP!
Tony Parsons
Level 3:
  • Nikon Master 6,405 Answers
  • Posted on Mar 18, 2017
Tony Parsons
Nikon Master
Level 3:
Answers
6405
Questions
Helped
1652113
Points
20272
You cannot create new folders on an SD card and copy images to them, as the camera will not recognise them, since they were not create in the camera. Copy the entire contents of the card to a folder on your HDD, then format the card in the camera.
5 Related Answers
Richard Schabler
  • 109 Answers
  • Posted on Jan 19, 2010
SOURCE: Will my Coolpix 5600 use SDHC SanDisk cards?
Sorry to say, but . . . No!
Cnet Reviews shows the specifications on your camera.
2167fde.jpg It only goes so far as SD memory, which is limited to 2GB.
It's a hurdle technology manufacturers had to jump, and now consumers must jump also.
Anonymous
  • 11967 Answers
  • Posted on Jul 25, 2010
SOURCE: Why can't I connect my Coolpix s3000 to my Vista
Try using a separate card reader to download your pics.
  • 102366 Answers
  • Posted on Dec 06, 2010
SOURCE: My Nikon Coolpix P3 camera is not accepting my
The P3 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to go with SD cards, 2GB and smaller.
Anonymous
  • 109 Answers
  • Posted on Jan 23, 2011
SOURCE: i have a sandisk sdhc
I would try to insert it in your PC and then format the card. Then reinsert in your camera and
see if that helps.
Anonymous
  • 107 Answers
  • Posted on Jun 13, 2011
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
1helpful
2answers
How do I download pics from camera to laptop, there was no software in Coolpix L330 bundle?
Often, if you simply connect the camera to your computer by the appropriately connectored USB cable (the camera is likely to have a mini connector; there may be one with the camera) the computer will recognize the camera, and ask if you want to download pictures using the windows wizard that exists for the purpose. You may need to be connected to the internet if you want your computer to search the internet for installation/or appropriate software.
23.January.2015
When i plug my nikon coolpix s3000 into the computer it registers the camera but it wont retrieve the pictures. it say the computer cant detect it. HELP
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
I want to upload my pics from my Coolpix L110 camera to my macbook pro. I've downloaded the Nikon transfer and View NX software suite but when I connect the camera via USB chord my computer doesn't detect...
Pros avoid this problem by using a card reader and downloading to a folder they create on their desktop. From there, the pics can be imported to the program of your choice.
Hi i have Nikon coolpix s3000 and im not able to transfer pics to my PC. Unable to know when my camera is on after attaching USB
Try connecting the cable to the Coolpix and then turn on the camera before plugging the USB cable into the computer.
Another way to transfer photos to the computer.
Remove the memory card from the Coolpix and insert the memory card into a USB memory card reader then connect it to the USB port on the computer. The computer will see this as an external storage device, you can then open the folder/s and copy the photos from the memory card to the computer.
2answers
1helpful
My nikon coolpix s3000 wont download pictures to my computer
Hi
I used to have a very similar problem with mien, I couldn't download the pics from the camera. The problem was in the camera that the computer didn't recognize it.
The solution that worked for me was the following.
I bought a card reader ( a cheap one cost around 10$ US)
when I used the card reader
with the camera card I could access the pics without any problem and transfer them as easy as earlier.
if you find a solution to the problem please post it here
Thanks
2helpful
Nikon coolpix sd cards read empty in any computer but when in the camera i can see all the pics and sd card reds almost full
This happened to me before with a Nikon Coolpix camera as well. this is due to a virus obtained by the memory card when I inserted it to a friend's computer. What I did was I typed in the direct path of the pictures folder into the address bar, say if you are using a memory card reader and says F: as the drive for your device, you can try to go directly into the pictures folder by typing in F:DCIM and press enter. Once you are able to access your pictures folder copy them all into your computer and format the memory card after using your camera and you are ready to go. Hope this one works for you.
I am trying to download pics from my Nikon coolpx to my IMac but iphoto does not recognize the camera - what do I need to do?
First, make sure that the Computer recognizes the Camera when connected to it using the USB cable.
When the computer recognizes the connected camera then a "No name" drive appears on the Desktop of the computer.
If the Computer is recognizing the Camera but iPhoto then follow the steps given below to transfer images from the Camera to the Computer:
Double-click the "No name" removable drive on the Desktop to view and navigate through the folders and files on the Camera.
You can see several folders, you may either navigate through each folder to locate the folder that contains the pictures or double click the "DCIM" folder to view all the images.
Next, copy all the desired images then paste them on the Hard Drive of the Computer.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
