SOURCE: can you tell where the spark plug is located on an
My polaris sportsman 500 4x4 battery drains badley when the headlights are on
SOURCE: 110cc aeon cobra losing power
sounds like clutches need maintainance.other things could be a stretched belt.bad plug.partially blocked exhaust.but usually a worn clutch is most likely the cause.you can check the belt while you are there
