Some oven doors have adjustable springs and some not. If adjustable, tighten down the nuts until the door closes. Also check to make sure the hinge arms are not bent. Open the door and it should stay open in a horizontal position. If it falls lower than horizontal, the hinge arms may be bent. You will have to remove them to straigthen them or replace with new.
Where are the adjustment nuts?
If the hinges stay in the oven when you lift the door off, the adjustment nuts will be on each side of the oven. (You may have to remove side panels) If the hinge comes off with the door, the adjustment will be inside the door. It will mean you have to strip the door.
