Do you still have your Lenovo G555 manual? "Try to read when connecting to the projector section"
I will give you some universal function keys to solve your problem
press and hold this:
Fn F3
Fn F4
Fn F5
Fn F6
do this one at a time
others does not function with Fn they use ctrl button. Try to press and hold ctrl with the button mention above with not pressing Fn
Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
