Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
If you have an answering machine connected to the same
line as the fax, set the answering machine to answer incoming calls before the
printer does. Increase the number of rings by a factor of 3 over the answering
machine. For example, if the answering machine is set to pick up on 4 rings,
set the printer to pick up on 7 rings. If you have a voicemail feature in the same line as the
fax, you may subscribe from your phone service provider for a distinctive ring
pattern feature. You can program your printer to have a distinctive ring
pattern and phone number for incoming faxes.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
1. Can you take a picture of the back of the setup and also where it is connected?
