Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
Posted on Jul 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the start.
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Jul 25, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
75035
Points
223
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
  • Ruth Patton
    Ruth Patton Jun 30, 2014
    Thanks for your help
2answers
Code 90 on my Intex Salt Water ECO15110-2.
Low Flow Error. Check valves are fully open and basket filters are clean. Videos that my help.
https://www.google.com/search?q=Code+90+on+my+Intex+Salt+Water+ECO15110-2
After modifying our 20x 48 Summer Escapes pool to utilize our Intex Saltwater system - why is the saltwater pump showing low flow?
Index salt chlorinators need a certain flow rate. Check the flow rate on your pump to see if it is strong enough.
4helpful
2answers
What is a code 93?
Code 93 = Good News for You! :-D It is your Saltwater Chlorinator's way of letting you know that it is working properly and your pool's water has a level of salt that is optimal/good.
Code 93 just lets you know it is not actively converting salt to chlorine...it is in 'standby mode.' When you first programmed the number of hours you wanted it to run (by pressing the left (down)arrow until you heard the beep, then pressing the right (up) arrow until you heard the beep - then pressing up until you reached the desired number of hours you wanted the unit to operate (minimum 1 hour, maximum 12 hours)) the unit began converting salt to chlorine immediately.
This is good news for you. Once the number of hours of operation are up, your unit will give you a code when you press either button. If your salt level is too low, you will receive code 91 indicating this, if your salt level is too high, you will receive code 92 indicating this, if the water flow is too low, you will receive code 90 indicating this (this gives you the opportunity to correct this before the next cycle begins. If there is no error with your pool's water, your unit will go into standby and wait until it is time to run the numbers of hours you programmed it for (it will begin it's cycle at the same time each day unless reprogrammed by you). When this happens, you will find code 93.
So, just to recap:
Code 93 = Good
Code 92= Salt level too HIGH (Empty approx. 20% of pools water & refill with fresh water.)
Code 91 = Salt level too LOW (Add salt.)
Code 90 = Low Water Flow (Check your filter. If it is working properly, you may find that it is too small for your pool. The filter that came with my pool was FAR TOO SMALL - I spent more time cleaning the pool than swimming in it. My 18' x 4' pool came with a 1500 filter. Now, I have a 4000 Sand Filter. This + the Saltwater Chlorinator = practically no maintenance. Together, these were approximately a $500 investment. WELL WORTH IT!!!)
Code 88 = Startup mode. (Press down arrow until you hear the beep. Press up arrow until you hear the beep. Press up arrow until you have the unit set to operate the number of hours you desire.)
As an extra FYI: The unit works with the sun. This means the unit turns the salt from your pool into natural chlorine which is then sent back into your pool. The sun turns this natural chlorine into salt. Your filter sends this salt into your saltwater chlorinator where it is again converted into natural chlorine & returned to your pool where then sun...I think you get it. ;-) It's a continuous process. ~This being the case, when you program your saltwater chlorinator, it is best to set it up to help it work with the sun rather than setting it up to compete with the sun. You do this by programming it to run at night. This way, your unit isn't working hard to generate chlorine at the same time the sun is diligently converting the chlorine to salt. I've read several articles where people argue that you should run your saltwater system at night & your filter during the day. I don't understand this concept. My filter runs 24/7 & my saltwater chlorinator runs 12 hours - from 8pm to 8am. Since I set my pool up to operate this way, I have not had to clean it at all other than backwashing the filter every other month just for principle. My water is crystal clear.
One further note of interest: My pool holds approximately 6000 gallons of water. For this, Intex recommends 135 pounds of salt. Because of some advice I'd read posted by other users, I started with only one 40lb bag. This was all my pool needed. Approximately once/year, I add one more 40lb bag.
RJBALLZER777, because you are receiving code 93, I realize you have set your pool up correctly and, therefore, are possibly thinking, "Why is she telling me all of these things I don't need to know?" I apologize if that is what you are thinking. I am really posting for those who have not gotten it just right the first time (or who are doing their research before buying as I did) so that they may get several questions answered at once. Hope you don't mind that I used your question as a means to post. (That's why I answered your question right off the bat.) Hope this post helps some.
4helpful
What is code 90
Code 90 is low flow indicator
you have air in the system or a blockadge
open bleeders while pump is running for about a minute to release air
If that does not work check your hoses
Usually there is a build up right at the motor where the water goes in
1helpful
2answers
New pool and keep getting code 90. intex sent a replacement system and I'm still getting code 90
code 90 indicating low flow.
Do you have a good flow from inlet to outlet? You should be shooting a pretty good stream (wave form) across the pool. You can remove the filter from the pump and run it without to see if you eliminate the error. if that works you've got some gummy filters going on that require cleaning or replacing. (daily in my case) If the error persists check the flow sensor on the chorinator. Be sure the direction is correct, the water coming into the chlorinator follows the direction on the electrolytic plate box. (usually there is arrow on this. Other thing is, how loud is the system? Are you hearing lots of air entering the intake of the pump? This can lead to air lock on the pump and little to no flow in the system. If so, bleed the air of using the relief valves at the top of the filter and at the input of the filter. Also listen to ensure that the inlet at the pool is not allowing air to be sucked into the lines. This can be due to a loose connection or bad gasket at the inlet valve of the pool.
24helpful
3answers
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
Water flow error
Water Flow should be like this
Pool Water-
Salt water system flashes 90
Hi. Have you cleaned the flow sensor? Make sure that it moves freely throughout it's full range of motion. Sometimes things eventually will fail. If you have completed your checklist and the above mentioned then the replacement of the sensor unit seems to be the next logical step. Happy swimming
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
