I fixed the problem on my coffee maker fast and cheaply! I found that the stem that the grinder sits on had a small crack vertically in the hard plastic. That caused the diameter of the stem to swell just a bit larger and the grinder to bind to the stem. My solution was to remove some of the material in the area that was binding on the stem. Since the motor for the grinder turns at a high speed, I let it do the work. A file worked very well for the job. I by-passed the safety cut-off plunger, by pressing a rod into it, hit the on button, then carefully held the file to the area to be filed. I then used medium sandpaper to smooth everything
If you try this, be sure to not take off too much material and only file in the affected area. Also we are by-passing the safety switch - so obviously use caution. I only did thiis a couple days ago but so far the ginder comes out very easily. Here are a couple picts.
Same problem and I'm the husband that always got it unstuck...... until this morning. I read somewhere that putting the whole machine in the freezer will work. I did and the grinder just lifted out without any pressure at all! My wife was laughing at me when I was looking on line for a solution but she just smiled when it was removed.......
Put the whole machine in your refrigerator freezer for 2 hours. The grinder basket should now come off. Take the whole unit to your shower and rinse it thoroughly in plain hot water. Dry it. Then look at the point where the basket joins the brewer. You should see a little spindle and a set of helical gears. You will see the same helical gears on the basket itself. Now, spread white lithium lube on the gears and the spindle. None of this is anywhere near the water flow so you won't get lube in your coffee. All of this should solve the problem of the stuck basket.
jsdemott
Experienced the same problem of grinder being stuck..... ordered a new grinder unit (including cover) thinking it would solve problem. It did not!
New grinder has a fresh new blade that probably works a little better than my old grinder. My solution was to remove the grinder with a screwdrive wedged in the back of the grinder cup-be careful when doing this. Once removed, rub some vegetable oil on the stem in which the grinder basket sits. A little oil on a paper towel will suffice. Makes the grinder removeable after use. I have done this each time I use the grinder and it has helped tremendously.
Instead of the freezer, put ice in the grinder cup. It came out after about an hour
I have the same problem (this must be a manufacturing defect if so many of us do) and tried the oil solution. It worked very well for a while and doesn't work anymore. I now buy ground coffee.
grinder basket remains stuck
I can't get the grinder out to clean. Is there a release button? Help!
The grinder basket will not release. I don't know how to remove it.
I have the problem as well.
Same problem here with two different machines.
Ditto here. aggravating!
There so much time devoted to making a d@#m cup of coffee with machine and all its parts. Now I have to figure out a way of getting the grinder cup out of the machine because it's stuck. If I'm successful I'll have to deal with yet another step of adding vegetable oil or mineral oil to the step. Yikes! I'll buy ground coffee from now on.
I have the same problem and came here to find a solution. The general consensus seems to be to buy ground coffee. Seems like Cuisinart got the better of us. quell dommage
i was so mad this morning when this happened , ugghhh, same problem , plus my grinds were caked inside and all i had was dirty water in the pot , i couldn't remove the grinder to clean it -so i scraped it all out and wiped it clean with a paper towel, took the filter basket out and had to clean it out underneath, than i took my vacuum and used the attachment and removed all the caked up stuff out for now ,, its a temporary solution until i can fix it and wash it the right way ,,, i have to have my coffee!!!!!!!
I have the same problem. I purchased a new bean basket but it also became stuck after a week or so. I now use ground coffee only. What a disapointment for an expensive coffee maker.
Same issue, grind basket won't come out to clean - what a mess. Itried to pry out with a screw driver or pull with a pair of pliers - NG. What poor design for a "high end" maker. I'm getting in touch with Cuisinart - probably tell me where to go, but I have to try. Thanks.
mine is stuck forever. My solution, opt for a french press, makes better coffee, has no parts to speak of, and you can microwave or boil the water to make it hot. Best cup of coffee ever and you can grind your own coffee.
Mine does the same thing and it seems to be getting worse! Anyone have a solution??
We have the same problem, I can never get the coffe maker grinder out, my husband has to do it - impossible to clean. Then the other day I think because of this problem the grinder went crazy and it seemed like the machine was going to take off, or burn out it's engine. We turned the machine off manually only to discover that some wires had come off internally, either burnt through or broken by the wirr of the spinning, it was a circular group of wires. Now the grinder doesn't work at all. Can't get a phone number or find a service center...they sure don't build things like they used to!
Same problem-grinder stuck in less than a month of use. So disappointed in Cuisinart - thought this was a quality line. Store where purchased out of business right after Christmas. Will NOT mail it back to Cuisinart.
