SOURCE: i have aquashift st 2000
If you look at the pump cabilities the max life is either 2.3 or 2.4 meters. I.e 7.88 Feet max lift. I looked up even the 5000 Liter per hour pump and it only has a lift of 2 meters. 10 feet is 3.048 meters. It seems your height requirement lift of 10 fee is greater than the lift capability of the pump. You can... install a second pump with a hidden reservoir at the 5 ft lift mark behind the water fall to get the desired flow. Or change to a submersible 1/2 hp well pump as most will give you 10 to 12 GPM flow rate and will elimate the 10 ft lift problem. A shallow well pump could be installed above the water (encased / hidden and provide you with 23 feet of lift.
The problem you have is the 10 ft lift distance is more than your current pump can provide.
Thanks for choosing FixYa.
Kelly
SOURCE: I set up a Laguna powerjet pump and a Laguna
Hi and welcome to FixYa I am Kelly. I suspect that the filter is not properly locked into position but.... I highly recommend you countact Laquna Experts. The can handle most 1st time install issues over the phone is just a short time. (Cordless phone recommened) CANADA ONLY: Toll Free Number 1-800-55HAGEN (1-800-554-2436) ..........Between 9:00 AM and 5:00 PM Eastern Time. U.S. ONLY: Toll Free Number 1-800-724-2436 ....................................................Between 9:00 AM and 4:00 PM Eastern Time.
U.K. ONLY:
Helpline Number 01977 556622 ......................................................Between 9:00 AM and 5:00 PM.
If they can not help you just repsond here and we will give it our best.
Thanks for choosing FixYa,
Kelly
SOURCE: The cleaning handle(S) on our
Hi genejo4boys,
Cleaning handles for this are replaceable. You may contact this number 800-352-4769. They do sell genuine Laguna Filter Replacement Parts. From Filter Foam, to O-Rings and UVC Replacement lamps to Service Kits and of course cleaning handles. You may want to check out with them.
Hope this helps.
Thank you for using FixYa.
CANADA ONLY:
U.S. ONLY:
U.K. ONLY:
Kelly
