Motorola Mobility CLIQ XT (2 GB) Cell Phone Logo
Posted on Jul 25, 2011
"Home" button doesn't work. Holding
"Home" button doesn't work. Holding it makes the screen try to Voice Commands. Motorola cliq xt
How to unlock my tmobile motorola cliq
Call T-Mobile at 877-453-1304 and request the unlock code for your CLIQ from a customer service representative.
  • 2 Slide your CLIQ's battery cover away from the camera lens and off of the phone, and then lift the battery out of the battery compartment and set it aside.
  • 3 Slide the T-Mobile SIM card out from under the metal band holding it in place, and then place a SIM card from another carrier in its slot.
  • 4 Replace your CLIQ's battery, and then hold down the "Power" button on the right side of the phone to turn it on. Your CLIQ will prompt you to enter a special code.
  • 5 Type your unlock code using the number keys on your CLIQ's touch-screen or slide-out keyboard.
  • tip
    With article and troubleshooting guide solution for Android Hard reset way
    • Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
    1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
    Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
    2. Power the phone off all the way, press and hold the Volume Down key and press then release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
    Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
    3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
    Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
    If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
    Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
    4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
    From the Android Recovery screen, press the Search key.
    Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
    Select Yes - delete all user data, and then select OK (again lower left).
    Select "reboot system now" and press OK.
    5. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
    While the phones power is off, press and hold the volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
    A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
    Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
    Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
    After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
    Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
    6. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
    Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
    The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
    Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
    Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
    After it's done make sure "reboot system now" is highlighted and then tap the Power button.
    In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
    7. Here is a hard reset for a Sharp Android Smartphone.
    While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
    Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
    Scroll down to Yes - delete all user data and then press the Power key to confirm.
    Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
    8. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
    After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
    Continue holding these three keys down simultaneously until the LG logo appears.
    Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
    If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
    The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
    If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
    Now you know how to hard reset an Android Smartphone and the next time your touch screen stops responding, your phone freezes, your phones power cycling, you forget your password, or pretty much any reason you wouldn't be able to perform a reset through the settings, you'll be set.
    If I have forgotten any key combos that you know of, leave the method in the comments below so that I can add it to the list. Don't forget to check out some of our many other popular posts and don't forget to power your phone off every couple of days and watch what applications you choose to download onto your device that way you can keep your phone healthy and efficient. Hope you enjoyed the article, have a fantastic day, and enjoy your phone.
    Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas
    Phonetolls
    on Jun 24, 2015 • Cell Phones
    1helpful
    My motorolla mb200 is power on but the screen is totally black or blank. what can i do
    if u r able to access the bootloader screen, (blue screen w/ motorola logo) then its probably 98% fixable. pull battery and reinstall, power up while holding the menu button, if it show the blue screen, u should b able to bring it back around to your way of thinking. you'll need to google the latest release of motorola RSD lite and down load it, and the correct firmware for your cliq, usb cable, and a pc w/internet. I have recovered mine and loaded a custom rom(cm7) on it using the info i found @ www.modmymobile.com they have just bout everything you'll need from device specific forums,links,technical info from real tech's, and devolpers. best of all its totaly free! just make sure you take the extra time 2 do some heavyish research, as there are several methods available, find the 1 thats right 4 u an ur phone and get to work, the worst that can happen already has, eitherway you'll have a new phone, if ya do try it, let me know how ya did. just post it here. thanks, and good luck restorin ur cliq. dholl1
    2answers
    I can't get rid of my voicemail icon on my Motorola Cliq. I don't have a voicemail.
    Do backup your data and do a factory reset going to settings . That should fix it .
    6helpful
    3answers
    My ipod touch is stuck on a screen that says "ipod is disabled, try again in 5,785,421 mintues"
    Connect your iPod Touch to your computer. Turn your iPod Touch off (hold down the top button and slide the red off slider). Then hold down the top button and the home button for ten seconds then let go of the top button while still holding the home button and KEEP holding it for up to 30 seconds. If it doesn't work the first time, try it again - iTunes should pop up and say that it sees an iPod Touch in restore mode. Click restore and you'll be able to get it back up...
    T-Mobile Dash Voicecommand: What keyboard keys map to the "app1" through "app6" keys in the Voicecommand application?
    The key to use for voice commands is the HOME BUTTON. This is the button that has the shape of a house on it, to the right of the green send key. Set the app to none or app 1, and it should work. It has only worked a few times for me though; it is kind of confusing. So, good luck. Also, there is an online voice command help. Go to voice command, click menu, click help.
    I have the motorola cliq and my moto blur aplications such as my happenings, messaging, and contacts will not load. How can I fix this?
    Make sure all your passwords and accounts are correct in your "accounts" menu (it's on the page after the home screen a red "motoblur" logo. If that doesnt work try deleting some of your msgs etc from a computer. If you have too many msgs it always has to retrieve all of them on start up.
    Motorola Cliq-Home Key Issues
    Try doing a hard restore
    1. Shut down the phone
    2. Hold the power button & camera button until a triangular picture pops up
    3. Let go of the button that it tells you to.
    4. Press Alt+S when your at the triangular screen
    Motorola K1 voice command problem
    Hit your Voice command button on the right upper outside of phone, Hit Settings Hit 1 make sure Automatic is Checked, hit ok
    Now Try Voice Command button again, and then hit your upper Right Softkey for Help on commands...
    Top Motorola Mobility Cell Phones Experts
    AFIFUL HAQUE MUFTI...
    Level 1 Expert
    vince
    john h
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
