Heating & Cooling Logo
Posted on Jul 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung dehumidifier model HD4080A I'd like to get a drain tube. Do you know of the kind/size I need? If so, please provide. Thank you.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jul 25, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103366
Points
14643
Generally, all that is needed is a section of garden hose, no longer than 5 feet.. The female connection of the garden hose attaches to the male drain hose connection on the unit. A water hose for a washing machine will work,
Hope this helped you and thanks for choosing FixYa.
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
1helpful
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
6helpful
3answers
We have a Frigidaire 70 pint dehumidifier (model LAD704DUL). We hooked up the hose so we could use the continuous drain feature but the unit just keeps draining into the bucket. We followed the...
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Where can we get a part to plug the hole so the water will drain out the hose? The hole is not round so it makes it more difficult to plug. HDN 655E 65 pints Thank you. Bob
Bob, you don't need to plug the hole for the water to drain out the hose. Once you remove the hose connection cap and connect a hose, no longer than 5 feet (a garden hose will work), the water will drain from the hose and not into the bucket. That is, unless the drain tube is clogged. In which case, an 18" long, plastic, Zip Tie, appropriately sized to fit in the hole, works well to unclog it.
Hope this helped you. Please let me know. Thanks.
DEHUMIDFIER STILL WORKS JUST WONT DRAIN WITH HOSE.
If it won't drain thru the hose, but is draining into the bucket instead, the problem lies either in the hose or the hose connection on the unit. Either one of the other is clogged. Remove the hose first and check for a clog, If none there, it's in the hose connection on the unit.
Use an 18" long, plastic Zip Tie appropriately sized to fit in the hole. Or something similar (NO wire coat hangers, though) and carefully insert it into the hose connection opening. Continue to insert it, until you reach a bend in the tubing. Work it gingerly pass this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Then, while rotating (twisting) it, slowly pull it back out. As you reach the end, be prepared for some water to follow.
Also, keep in mind the hose should be no longer than 5 feet and slope downward from the humidifier. It has no pump and relies entirely on gravity to drain the water.
Hope this helped you to troubleshoot and solve the problem. Please be kind enough to let me know. Thanks.
4helpful
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
2answers
My DeLonghi dehumidifier is collecting water but not into the bucket. Rather it leaks it all on the floor. I have cleaned the filter and even the coils to no avail. Please help.
The drain tube that drains the water into the bucket is clogged and needs to be cleared.
To do this, you will need at least an 18" long plastic Zip Tie or something similar. (But, NO wire coat hangers) that will fit into the drain tube or hole. Carefully work the Zip Tie into the hole or tube and gently push it forward. You will reach a bend in the tubing, but you will have to gingerly work past this bend. Once the Zip Tie bottoms out or you run out of Zip Tie. slowly pull it back out while rotating it. This will help breakup the clog. Once you start reaching the end of the inserted Zip Tie, be prepared for some water to follow.
The above procedure should solve the problem. Please let me know. Thanks.
3answers
Haier drain tube keeps popping out during/following drainage.
are you able to glue or put a hose clamp on the hose.hope this helps
Top Heating & Cooling Experts
Paul Carew
john h
