Homelite ZR10926 16" Chain Saw Logo
Anonymous Posted on Jul 25, 2011
We are replacing old doors only in an old house. when we put the hinges on the new door the bottom hinge is slightly misaligned. when we get it put together it binds
A
Anonymous
Move your bottom hinge up 3/4" so you have new screw holes -or- install bigger hinges that use different screw holes.
Put the screws into the door and into the door frame, but do not tighten screws all the way > leave screws out 3/16" so hinge is loose.
Hang the door with hinge pins. The screws are still loose.
Then while the door is hanging, tighten the screws a bit at a time.
The problem now is that door and door frame have 3/4" slot that is cut into the wood for the old hinge. Good news it that slot is at bottom and not as noticeable. Fill slot with filler and paint or stain to match.
Anonymous
Level 2:
Sergeant:
  • Expert 281 Answers
  • Posted on Jul 25, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
281
Questions
0
Helped
59505
Points
738
Hi this is what I would do. 1.buy a shim pack at any hard ware store (wooden wedges) cheap. 2.take one side of bottom hinge off,frame. 3.shut the door and use shims end to end like this >< Where needed to fit door,some on bottem ,one set on knob side and anoughter set on hinge side.At any rate where ever they are needed to leval the door in the frame. 4.buy some wooden dowels to plug frame holes,might have to drill screw holes larger for dowles.Drive dowels in and break them off. 5.swing bottem hinge in to place and screw hinge down.This should work and you may need a wood chissle or flat screw driver for modifacation where hinges seat.You may have to reseat both hinges or put shim stock behind the frame hinges to line up every thing.I hope something here will help and please feel free to ask any questions that you have and add any thing that will help me see this clearer.You will need a person on both sides of the door to drive the shims togeather to keep the door level. Thank you for choosing FixY.com..................Darryel
  • Anonymous Jul 25, 2011
    I had a senior moment sorry,once your door is plumb in closed position mark the shims or use a tape measure and level so you can get the level when you open the door to reattach the bottom hinge I am assuming that the hinge will be behind the door when closed.End result the hinges will be close to vertical.Don't put much weight on the top hinge or it will tweak. Send a picture if need be,this is just guess work at this point. GOOD LUCK!..................Darryel(I have hung doors before on old houses and have some Idea what your up against)
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Freezer door opens very slightly when refrigerator door is shut. How do we get it to keep from popping open?
there are only two things I know of that will keep the freezer door from closing . First , visually inspect the freezer door seal that goes around the outer edge of the inside of your door . If it is out of shape , torn, etc. , replace the seal . If OK , then your door hinges are probably worn down . Sometimes , you can adjust the hinge plate which will align the door enough to close properly . Remove the top hinge cover plate with a screwdriver or nut driver to access the three adjusting screws holding the hinge plate in place . Be careful to not misalign the door worse then it is already . It may take a few times with trial and error but it can be done . Of course replacing both hinges is the best option . a specially the bottom one as it is the load carrying hinge .
1helpful
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
1helpful
How do you replace the drivers door hinge?
The hingepin is available in some of the help kits at the parts store. If you are just trying to make the door tight again there is no reason to unbolt the hinge. You just grind or chisel the top shoulder of the pin away and then punch the old pin through the bottom.
Put the new pin through the hinge and bend a shoulder on the new pin. Some may even use a nut with threads.
To install the pin or replace the hinge you should open the door and try to brace the bottom of the door with a bucket or books or anything where you can keep the door from changing position. Once braced, a hinge will just unbolt and you can swap it with the new part. Do one hinge at a time if you have 2 on a door.
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Door won't stay shut
I don't know if it will work for you, but I had the same problem with an upright freezer. My wife told me an old trick is to put petroleum jelly on the seal to make it stick and it worked. It does sound like you might have the door hinges misaligned or loose. Grab the top and bottom hinge and wiggle them up and down to see if they are loose. Best of luck to you
1helpful
How do i replace the gasket on a top freezer refrigator?
Hi, first you will have to remove top freezer door, remove plastic cover from hinge, at left or right, above door, remove top hinge, tilt door slightly forward and lift off, be careful with spacers between door and hinge, you have to put back spacer between door and hinge to get proper alignment. put door on flat surface, lift rubber and check underneat, you will see screws or plastic clips, if there's screw, make like 3 or 4 turns with screwdriver, dont completely remove screw, if you don't have, don't know what type of ref. you got, remove old door gasket, replace new one, and put it back on. good luck.
1helpful
2008 F-350 Super Duty Super Cab doors Rattle
sure :while not hearing of any going bad on something that new(08)
ford allways has had a problem with door hinge pins wearing
and not allowing latch to line up hence it does'nt close tight and rattles
simple sat. day fix for you and a buddy
obtain new hinge bushings (brass) from NAPA
or other store have buddy raise edge of door tap out old bushings with pin punch and hammer ALL FOUR) tap in new ones use a plastic punch if possible to save dammage to new ones
take red crayon and put a line on top and bottom of latch pin shut door and open again What crayon line is missing
top line loosten bottom door hinge move up slightly tigthen bolts
Bottom line missing adjust bottom hinge down then repeat test
till both crayon lines are still there
door is now centered
it won't rattle now
closes easyier too
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
