SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
SOURCE: I have the American Standard
Is this in the basement and if yes then you have a brake in the pipe some where because you say that your snake is stopped by cement.
SOURCE: My american standard jacuzzi tub is pluged in but
check for power at plug in if power your vacume switch is probably out replace switch.
SOURCE: how to remove jets from american standard jetted
Jet trim usually unthread counter clockwise out of the wall fitting
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
