With power on and volume up, my keys produce no sound when pressed on my Williams Digital Piano Sonata 88. All other modes of audio work fine. I have been told there is a reset button, but I cannot locate it anywhere! I've had it many years, so it is beyond warranty. The LCD screen does work. Is there anything you can do to help please?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sounds like either there is a problem with a low frequency driver or perhaps an eq setting.
If you have an external (line) output, you can try sending the signl through another amp. If you have headphones, then try them also. If the headphones sound distorted as well,then see if you have the eq to high on the bass.
Other than that, it could be a filter capacitor in the power supply. You would need some experience fixing that.
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Assuming this has worked in the past (otherwise if you have changed to different pedal that is the problem) the usual thing is the machine samples the state of the pedal at power up and assumes the polarity of the pedal is at rest. Make sure you are not pressing it as you power up. Also verify the pedal is COMPLETELY plugged in... sometimes they are not quite fully in and that causes a problem, especially with the two stage versions that are sometimes used.
If this is a brand new unit, exercise your warranty!
BUT FIRST see if packing material worked through the speaker grill... you know littel pieces of the packing peanuts or otherr contamination that sits in the speaker cone and rattles.
