Restart the computer. Right click on the task manager > Task manager > End all the programs in Applications folder.
All the best.
Santo
SOURCE: Acer AL1916W 19" LCD Monitor color has changed to blue
hi
plz check your pin which goes to cpu.if there is any bent pin then correct it but be careful if the pin brokes then you have to replace the whole thing.
Otherwise you have to show your monitor to a qualified professional
Testimonial: "Has it really been four years since I posted my problem? I almost forgot that I even had an account on FixYa. Past me says 'thank you very much' and present me apologises for this reply to take so long. I ended up buying a far better monitor, so I just kept the old one."
SOURCE: Acer 1916w dissassembly
Eventually I found a workaraound.
Unlike normal mode, When in Graphics mode, the monitor does not start buzzing.
A point I forgot to mention is that hitting the monitor makes the noicse go away, but after a few minutes it slowly creeps back!
SOURCE: Moving line in LCD monitor
Just change the 4 capacitor near of the regulator area of the power supply...
that will fix your problem
SOURCE: display smaller than screen capability
GO TO CONTROL PANEL ,,DISPLAY OPTIONS,,, CHANGE YOU RESOLUTION
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
