Hello, I am having an issue with my Ipod. It gives me an error code when I plug it in saying that it cannot sync because the files or directory has become corrupt and unreadable. Someone on the Apple site suggested (to someone else with a simular issue) that this could be caused by locked files in the directory. I am good at following step-by-step instructions, but have no clue how to even access this directory so I can *see* if anything is locked. Any ideas? Thanks!! recently my computer broke,i can't use it anymore,and im using my laptop , i downloaded itunes and everything i needed for my ipod , i synced it ,and now it won't sync again . i really need to sync it . i've tried everything, it just won't work. what should i do?? any one , please!!!=D
SOURCE: Ipod won't sync to Itunes
maybe - just maybe - if you plug it into your computer and then, if a mac, do the 'get info' bit and look for the info regarding if a file or device is locked.
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Because you have all your music already backed up onto your pc you can safely erase your ipod. Have you already tried to do a restore on it yet. To do this connect the ipod to the pc and in itunes on the ipods main screen click the Restore button, then choose the bottom most option if it gives you any. If it says to erase the device anywhere, all the better, select that one.
If that doesn't work, assuming you're on a pc and not a mac, open 'My Computer', right click the ipod, select 'Properties' then erase it as you would any harddrive. Once you have done either of these you can resync it in itunes.
All the best
Sean
you should have updated your ipod software in piracy please try to load an original one
I have had the same problems, did all types of restores, formatting, downloading itunes and nothing has changed. I went through about 5 ipod classics because of this problem, Apple could not help me on bit. I later on found out the problem.... My case for the ipod had a magnet inside it which messed up the hard drive causing me to get all types of errors when i tried to sync it or just tried to listen to it. Hope this helps.
when i connect my ipod wire to the computer it tells me the usb connection has a firewall wat am i suppose to do
i have the same problem
ipods with hard drives **** i went through 3 ipod videos and 2 ipod classics but i still have 2 of the oldest thinest ipods. nano 1st gen and ipod mini 2nd gen they still work great. and the classic i have now is about to break
Hello, one question about your problem, what is the OS of the computer your using and witch specific generation/type of Ipod is it?
