Question about Jensen VM9424 Car Video Player
My Jensen VM9424 keeps shutting off everytime it gets too hot outside. The radio turns off and it completly shuts off my whole car. Its not a battery problem bc my battery is new. Any suggestions or ideas?
    New Friend:
    Problem Solver:
  • 5 Answers
Make sure the fan opening at the rear of the unit is not obstructed. It cannot cool itself is this opening id blocked.
Posted on Sep 13, 2011
6ya staff
SOURCE:
My hot point wma30 washing machine just keeps filling with water when switched of and Dior open
Turn off the water where the water comes out the wall. The hot and cold should each have a shut off valve...like your outside water where the hose hooks up. If the valves are frozen try moving them with a little force back and forth to see if you can get them to move. Do not break them. If they won't move then you'll have to find your main line shut off valve to shut off the water to the whole house.
I suggest calling a handy person to help you to shut off the water at the washer and then call a washer repair person to replace the internal washer shut off valve and/or sensor.
Mar 20, 2016 | Washing Machines
. Keeps shutting off
This is a sign of a bad or low battery. Try swapping batteries with a known good unit to see if the problem is solved. It takes more energy to transmit than to receive, so as you described a radio can receive messages, but then when you go to transmit and use more energy the battery will not have enough power to do so.
Best regards.
Apr 01, 2014 | Motorola MR350R Two Way Radio
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
I have a new vm9424 that was put into a 2005 h2. Main problem is i can reset the time, but once i drive it for more tha a mile the clock keeps resetting its slef to a /12 hour later than it is.. nor a...
CHECK THE CLOCK BUTTON SOUNDS LIKE ITS STUCK. IF ITS A TOUCH FACE SET THE TIME THEN MAKE SURE YOU GET OUT OF THAT PROGRAM AND GO SOME WHERE ELSE IN THE SYS. IF THAT DONT WORK SEND IT IN FOR WARRANTY REPAIR,
May 26, 2011 | Jensen VM9424 Car Video Player
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
WHERE CAN I GET A MANUAL TO INSTALL A BLUETOOTH SISTEM MODEL VM9424 TO MY FORD EXPLORER
Hello there,
Here is a link to the PDF file that you need
http://audiovox2.info/docs/jensen/man/VM9424_DOC_IM.PDF
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Jensen GPS
CLOCK RESETS TO 1200 EVERYTIME THE CAR IS TURNED OFF
There needs to be a constant power wire for the clock in order for the clock to keep time. You are losing power completely when you shut off the engine. Changed your battery lately or had a car stereo installed?
Sep 10, 2009 | 2004 Oldsmobile Alero
UV7I Volume Control Problem
they all do that ive tried you just have to deal with it it sucks but life goes on wright wright
Dec 17, 2008 | Jensen VM9510 Car DVD Player
My indash jensen radio keeps shutting down when turned up?
Sounds like there's a power problem. First take out the radio and leave it connected. Turn on the radio normal volume, then disconnect the radio's antenna. If the radio shuts off then you need a better ground. If the radio doesn't shut off then you need to run power wires to the fuse box.
The only other thing is you have a bad speaker that only shorts out when you turn it up. Disconnect all but one speaker or one speaker at a time and see which one is the problem.
Jul 08, 2008 | Jensen Car Audio & Video
Jensen VM9424 Car Video Player Logo
208 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
