SOURCE: Problem with Brand New Sharp LC-46SB54U
The problem is in the component video jacks, and AFAIK there is no way around it. What I did was buy an HDMI cable for my cable box, and a VGA cable for the 360. Bad thing is, the TV will not accept 1920x1080 through the VGA port...but it WILL fix the blinkout issue with the xbox. So, those with older 360s have the option to either upgrade to a HDMI 360 (min $200) or buy a $40 VGA cable.
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
SOURCE: No sound on Sharp Aquos 37' LC-37D4U
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
SOURCE: Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
If you have no sound and no video but you have power to the tv then you have to look at the source. Source being your Cable box. The other thing to check is to make sure that you have the proper input selected on the tv. If you have cable in Video one for example then you need to have your TV input to video one.
