Question about KitchenAid Artisan KSM150PSAQ Stand Mixer
Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on springs. I put them back. Net result is it won't turn on. Can you help?
    Novelist:
  • 153 Answers
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Posted on Jul 24, 2011
SOURCE:
KitchenAid Speeds are offset
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
Oct 04, 2017 | KitchenAid KSM150PS Artisan Series Stand...
Mixer won't turn on
Just recheck that you really have put the brushes back in the right way, use a torch and look in the hole. The brushes can each go in 4 ways, only one of which will work. Look for the blocker and line it up with the cut off corner on the brush. It's normally at the back, one side at the top the other at the bottom. After that you need to be looking at everything you have done for a booboo. I doubt it will be water ingress. Make sure the switch contacts come together when the lever moves to position 1.
Mar 18, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
It fell from the kitchen bench - ws working afterthis but sounded a bit funny so I pulled out the 2 side screws and back screws - no not working - need help to fix it!
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Inspect all the moving parts: Speed Lever, Speed Link, etc. and
make sure nothing is loose, bent or broken. Tighten all the screws
if necessary. Finally, adjust the mixer speeds if needed:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 24, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Hi, the speed lever won't move. I have checked that the bowl is securely placed and adjusted the height of the beaters? Can you tell me what else might be the problem. I have only had the appliance...
The Speed Control lever is linked to the Speed Link mechanism, which in turn moves the
Speed Control Assembly to allow the motor to operate at different speeds.
Get a Repair Part List from Kitchenaid.com for your particular model to see how it works.
As you select different speed setting, the Speed Link simply moves forward or backward,
thus pushing the Speed Control Assembly back and forth.
If you cannot move the Speed Control lever, means that the Speed Link is somehow bent
or out of place. Remove the Motor Housing and the End Cover and check it out.
Jul 01, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
Well, I was attempting to replace my speed lever. In the process I removed the back cap (electrical circuit board) and the two screws on the side (flat, springs with magnets attached). After I replaced...
Hello Lora,
I understand that you took you speed lever out to replace it and you took the brushes out of each side of the unit. The reason that the unit will not start is more than like the brushes are not installed the proper direction.
1. Unplug the machine
2. Shine a light in the hole on the hole on the side of the unit. You will notice a notch or a piece sticking out.
3. Take one of the brushes (magnet looking things) put the notch and the cut out in the same corner.
4. Repeat the samething with the other side.
5. Plug in and check and see if it runs
This should solve your problem with the brushes. IF you have any more questions about this mixer please post it to this discussion.
THank you for choosing FixYa.com
Justin
Mar 13, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Mixer just won't turn on -speed control jammed
Unplug the appliance. Take it to a well ventilated area and spray some alcohol in the slot where the switch is while trying to move it. This must be done with the appliance unplugged and the appliance must be thourughly dry when you plug it in. Use canned air or if you have one a compressor.
Mar 05, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KITCHEN AID MIXER WILL NOT WORK
If you have had the brushes out (under the big screws on each side) verify the cut corner of the brushes are oriented properly. Look inside the hole with a flash light and you will see where the cut corner needs to be.
Dec 31, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Recalibrating of brushes
You don't need to guess- get a flashlight and look in the hole.  You'll see a small piece of metal in each- on one side it's upper left, the other lower right.  Put in the brush so that the notch is on the same side at the piece.  If this does not work, swap sides.  This worked first time for me.
Oct 19, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid Artisan KSM150PSAQ Stand Mixer Logo
268 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
