Sony VPL-ES4 Projector Logo
Posted on Jul 24, 2011
1.how can I clean sony-vpl-es4 LCD projector? 2.what type of liquid can I use to clean? 3.how can I identify the lenses inside the projector?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
256
Points
Projector display to lcd problem picture lining problem
3 Related Answers
Anonymous
  • Posted on Feb 13, 2010
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Anonymous
  • Posted on Nov 10, 2008
SOURCE: vpl-es4 sony projector-frequency out of range
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
Anonymous
  • 4 Answers
  • Posted on Dec 24, 2009
SOURCE: HOW TO SOLVE FREQUENCY OUT OF RANGE IN SONY LCD
get a life u fool
3answers
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
1helpful
I have a Sony projector VPL-ES4 and the ON / Standby red flashes 6 flashes. I got the lamp, I cleaned the air filter, I tried to reset Left Right Enter key and the problem still persists. Can you help?...
check a small bord under the mother bord calld air sensor
its look`s like a transistor check the divice properly and change the projector frimware through computer
My sony 3lcd vpl-es4 shutting itself off after just few minutes
Problem might be due to the air filters being blocked.
Remove the cover and check for dust accumulated on air filters. Remove the dust with a small paint brush.
Let us know the result.
And thank you for using FixYa!
We have sony vples4 projector ,when i turned on it ,light is glow but after 5 minitus total projetcor is turned off
Does it switch off with an error message or the lights indicating a problem. is the power saving feature switched on.
is the air filter cleaned.
2helpful
How to rest lamp timer vpl-es4 - reset < > enter - doesn't seem to work
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Focus Problem
the lamp of the device may be going to end its life, need replacement.
15helpful
3answers
Vpl-es4 sony projector-frequency out of range
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
